02-04-2016, 08:50 AM
2006 23' Safari SE
Biloxi
, Mississippi
Double solar system hookup.
Another off the wall solar question. Is it safe to hook up two independent solar systems to the same battery pack? Ex: a Renogy 100 watt suitcase using a 10 amp controller and another independent 75 amp panel run thru another controller. Just a what if.
MICHAEL
02-04-2016, 08:58 AM
2007 30' Classic
Oswego
No, you should wire separate systems to a single controller. I installed connectors to my ZAMP portable system in order to remove the ZAMP controller while connected to the AS pigtail. I kept the ZAMP controller mounted to the suitcase so I could use the portable for other stand alone applications, but it is effectively removed from the system and creates a parallel with my permanent panel through a single Morningstar hard wired AS controller.
-Rich-
02-04-2016, 08:59 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Parallel connections are typically permissible as long as there is not a gross mismatch from one another!
It's basically like having your converter and solar controller together.
02-04-2016, 09:03 AM
2007 30' Classic
Oswego
Here is a rough drawing of my setup:
-Rich-
02-04-2016, 09:06 AM
2007 30' Classic
Oswego
Any mismatch of output voltages will cause reduced efficiency of the system....when in the cycle(s), and how much of a mismatch determines how much inefficiency. Theoretically, there will be times in their respective cycles where there is zero gain from one subsystem or the other.
-Rich-
02-04-2016, 09:22 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Voltage to the batteries is voltage to the batteries..... despite a differential.
02-04-2016, 09:26 AM
2007 30' Classic
Oswego
Negative. A voltage differential on a parallel circuit will cause resistance in the lower voltage leg, reducing the amperage from the lower voltage leg.
-Rich-
02-04-2016, 09:29 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Rich (dznf0g) pretty much explained all it. Friend here has a Renogy suitcase, same one you have with a 300 watt Renogy kit on the roof. He kept finding that the roof controller was still charging but the suitcase kept reading as full. Basically the systems were mismatched.
So I helped him bypass the PWM on the back of the suitcase, and we wired it with a SAE plug into the one controller for the roof solar. Works better that way.
The only good way to run two separate controllers is if they can communicate with each other. Like Bluesky and Victron units do.
For example, I have a the SB2512 and SB3024 - the 2512 is slaved to the 3024 for my ground deploy solar.
OUR BLOG | INSTAGRAM
02-04-2016, 10:10 AM
2006 23' Safari SE
Biloxi
, Mississippi
OK, bad idea. It was just feeble brain storming. I do have another new PWM 30 amp controller I could swap out the 10 amp Renogy unit and add the 75 watt panel. Effectively and guessing again would up my system to 175 watts or would that cause too much of a miss match? At this time wanting to stay away from hard wiring a solar system and keep it simple and cost effective.
MICHAEL
02-04-2016, 10:20 AM
2007 30' Classic
Oswego
I would need to know more about the specs of your two panels to comment, but if they are close in specs, you probably can parallel them into that controller.
-Rich-
02-04-2016, 10:24 AM
2006 23' Safari SE
Biloxi
, Mississippi
The Renogy panels are two 50 watt mono. The other is a 25 year old Siemans 75 watt that still puts out close to its rated amps. I used it on my boat for 10 years in the Carribean.
MICHAEL
02-04-2016, 10:33 AM
2007 30' Classic
Oswego
More specs on each please. Open circuit voltage (Voc), etc....as well as your controller specs.
-Rich-
02-04-2016, 10:55 AM
Racine
, Wisconsin
Running a Trimetric controller and monitor. All neg wiring goes through a shunt that monitor uses to monitor charging. Just got a 100 watt Renolgy suitcase, hooked it up to negative to shunt and batt positive terminal. Working very well.
02-04-2016, 01:06 PM
2012 23' FB International
Woodstock
Except that the lower voltage won't be doing anything! The higher voltage would normally feed back into the lower voltage except that the controller has a diode to prevent back voltage.
JCW
02-05-2016, 10:29 AM
1970 23' Safari
Ranchos de Taos
maybe a remote recepticle
Don't mean to hijack the thread but this seems like an appropriate question. I am going to mount 2 100W panels on the roof and have them wired thru a controller. Would it be possible to prewire a recepticle that is wired thru the controller and have the recepticle easily accessible on the outside of the A/S so that you can just plug in a suitcase solar array? That way you can just plug in the extra solar panels or not as needed? Tom
02-05-2016, 10:38 AM
2008 25' Classic
Full Time
For 200w on the roof, combine them and send the cable down to the solar controller location to another combiner box. Then lay cable with a quick connector from that combiner box to outside the trailer for the portable panels. Disconnect/remove any controller on the portable panel. Then connect that combiner box output to the solar controller inputs. Disconnect any controller mounted on the portable panels.
I'm planning to do this hopefully this year; 200w on the roof plus my 200w Zamp portable.
Kelvin
2008 Classic 25fb "Silver Mistress"
2015 Ram 2500 6.7L Cummins. Crew Cab, 4x4, Silver
02-05-2016, 02:44 PM
Naples
Be sure to use an A/B selector switch just ahead of your solar controller, as 2 sets of non-matching panels will not play nicely together into a single controller.
Lew Farber
RVIA/RVDA Nationally Certified Master Tech
ABYC Certified Master Marine Electrician
Master Tech Energy Systems, Inc.
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
lewster
02-05-2016, 04:55 PM
2008 25' Classic
Full Time
Really? So I can't really get 400w with say 2 AmSolar GS100 on the roof and two Zamp 100 of portable running together connected to either a Bogart SC 2030 or a Blue Sky controller?
I guess I need to buy two Zamp 100w panels for the roof if thats true.
Kelvin
02-05-2016, 05:14 PM
Nomadic
, USA
You can if all the specs match.
02-05-2016, 07:07 PM
2006 23' Safari SE
Biloxi
, Mississippi
Originally Posted by twh731
Don't mean to hijack the thread, Tom
Of course you did, but that is ok. The thread was dead.
MICHAEL
