06-17-2021, 10:22 PM
Georgetown
Kitchen sink drain detached
Hi folks,
Just purchased a nearly new 2021 30FB Bunk and drove it about 800 miles home. There were some killer potholes in Oklahoma that I think have jarred loose whatever supports the kitchen drain pipe. As you see in the photo it is just leaning forward.
Full story - the faucet had jarred loose as well and the bracket attaching the faucet partially broke. I was able to put the faucet back together, but the drain pipe is hanging so loose that the trap won't even connect to the sink. You can move the pipe easily up and down by hand.
Pics are the broken bracket under the faucet and the loose drain pipe.
Any ideas on where this drain pipe should attach to be supported?
thanks!
Gary
06-18-2021, 06:50 AM
1987 25' Sovereign
Fort Collins
Seems to me that if you loosen/realign/retighten the slip joints it should line up and hold. Maybe the slip joint on the p trap wasn’t snugged at the factory?
Alumacoot
“We are confronted with insurmountable opportunities.”
06-18-2021, 08:59 AM
Georgetown
Thanks but it just slips right out because there really is nothing to hold the sink drain pipe to the P trap.
06-18-2021, 09:02 AM
Little falls
, New York
There should be a little plastic collar inside the joint that holds it by friction. The connection aren’t under pressure so it’s just a regular sink tailpipe like you’d have at home. If friction doesn’t hold it take it apart, go to Lowe’s and re-engineer.
06-18-2021, 09:32 AM
Georgetown
Ok, I’m feeling a little dumb. Thanks guys so much! Once I put the rubber gasket on the drain pipe and then inserted in the p trap it held just fine!
I think because the rig is so new, things just are a little loose. It went right back together.
Thanks again!
06-18-2021, 09:36 AM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
Try that. (from civeng99)
It is not terribly uncommon for that to happen. On our previous 25 I put a small block of foam under the P-trap on the bathroom sink to make sure it wouldn't come loose. Snugging the collar helped but the foam solved the issue for good.
06-18-2021, 10:36 AM
2013 20' Flying Cloud
Westerly
, Rhode Island
Maybe I'm not seeing this right, but what is the other end of the drain pipe attached to, behind the cabinet, that lets it appear to flop around? Shouldn't that pipe be solidly attached to the rest of the plumbing system?
06-18-2021, 10:41 AM
Little falls
, New York
Likely nothing. The tip is just an in-line vent so it drains (doesn’t either not work or glub glub as it goes down the drain. Honestly I’d probably reengineer it as it will prob come apart again under vibration. But engineers have to well, overdo it
06-18-2021, 01:28 PM
Westerly
, Rhode Island
I mean the bottom of the pipe. OP says the drain pipe is "leaning forward". How is there that much flex in the piping that it can lean far enough forward to create that large a gap?
06-19-2021, 04:28 AM
Georgetown
The other end of the pipe is all solidly glued but still has a lot of freedom of motion up and down. I like the idea of putting a foam block under it so maybe it doesn’t bounce loose again!
Really appreciate how great this community is. Thanks folks
06-19-2021, 02:46 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Thanks again!
Yep! That IS a handy clean out. (If your wife ever loses a diamond out of her ring... loosen this joint and check. Big hero moment... after you clean all the gunk off.) I just periodically tighten it - about once a.month - because traveling vibration will loosen it.
