Old 06-20-2021, 09:17 AM   #1
Shower drain leak
30' 2005 Classic, forms a large puddle outside under the shower stall area, only after showering. I assume a failed connection to the grey water tank. Any experience would be appreciated.
drwayne is offline   Reply With Quote
Old 06-20-2021, 07:16 PM   #2
SandKSmith's Avatar
Phoenix , Arizona
Our 25’ 2006 Safari had a similar leak. The P trap was loose where it connected to the pipe that went to the gray water tank. I had to remove the heater vent in the adjacent wall and reach in to hand tighten.
Good luck,
Steve
SandKSmith is offline   Reply With Quote
Shower Drain Leak 2012 16' Sport debrunyon Sinks, Showers & Toilets 3 01-03-2021 12:28 PM
23FB Shower Drain Leak Rob Edgerton 2009-2015 Flying Cloud 6 07-13-2019 05:31 PM
Shower drain leak TayaraTravel Sprinter and B-van Forum 13 10-03-2018 04:08 AM
Shower drain leak - 2006 International CCD tanniwells Sinks, Showers & Toilets 4 04-18-2016 10:14 AM
'06 Safari FB Water leak from Shower Drain RichHog Sinks, Showers & Toilets 0 09-01-2014 03:35 PM
