01-30-2023, 11:31 PM
2011 16' Sport
2022 20' Bambi
woodinville
Truma AquaGo Comfort Plus Installation
We are not very happy with Girard tankless water heater comes with our 2022 2-20FB Bambi, it not only takes a while to get hot water, it also has inconstant hot/cold mixing for navy shower in boondocking.
After some research, it appears the best solution to get instant constant hot water is Truma AquaGo Comfort Plus, which has a small holding tank and can circulate warm water through the hot water recirculate line.
Unfortunately, Truma only offers AquaGo Comfort (Non-Plus) in dealer installation which doesn't have hot water circulation feature, The plus version is only factory option for now, we are out of luck unless Airstream can work with Truma to offer this option in the future.
So I scored a Comfort Plus which has winterization damage in the holding tank through ebay with stealer deal. And got the holding tank parts from dealer, it's quite straight forward process to dissemble/replace/assemble.
I also ordered control panel and a white access door and painted with metallic silver, it matches the airstream skin very well, has factory look.
I have tested Truma AquaGo Comfort Plus after installation. In any of hot water faucet/shower head, the hot water comes out just in a second, very impressed.
01-30-2023, 11:53 PM
2011 16' Sport
2022 20' Bambi
woodinville
The unit is exact fit. And the access door with XS size also fit perfectly
The door was painted with silver metallic, multiple coat sanded with 500 grit in between, and last clear coat
01-31-2023, 04:46 PM
2024 30' Classic
PORT SAINT LUCIE
, FL
Great score on the used units. I saw a shelf full of units that froze that people neglect to winterize at the Factory service center. They keep rebuilt ones there and sell them at $700 exchange but will not warranty as it's so easy to winterize.
01-31-2023, 05:37 PM
2024 30' Classic
PORT SAINT LUCIE
, FL
Forgot to mention. Always shut the power off at the remote before disconnecting the battery switch or an error will occur.
01-31-2023, 06:19 PM
2011 16' Sport
2022 20' Bambi
woodinville
Our unit was the last one of the bunch listing, all units had winterization damage at the exact same place. Totally agree, Truma has designed drain level in place but people just forgot to do so. They need to replace the whole unit to fix it
01-31-2023, 06:20 PM
2011 16' Sport
2022 20' Bambi
woodinville
Thank you for the suggestion, don't know this scenario will throw error.
02-01-2023, 09:18 AM
Paradise
The drain is the easiest thing to do. Pull yellow lever, remove filter plug.
Leave filter plug out.
If you put it back in, it traps water in the lower tube area, then pops. Leaving it out let's everything work out just fine.
02-19-2023, 06:50 AM
2023 23' International
Macon
, Georgia
Does installation of the AquaGo Comfort Plus require changes to the plumbing in addition to changing out the Girard? I have a 2023 23FBT. I am trying to decide whether to install a Shower Miser with the existing Girard, or go with the AquaGo Comfort Plus if I can find one.
Are there any other options to accomplish the same result?
02-19-2023, 09:34 AM
2011 16' Sport
2022 20' Bambi
woodinville
There are some plumbing work. Such as install warm water recirculating line from far end of the faucet to water heater. And the position of the hot water and cold water outlet of water heater is different, need adjust a bit in the water tank department.
But it is all basic pex piping work, not terrible difficult at all
04-02-2024, 05:12 AM
2019 19' Flying Cloud
glen allen
, VA
Since you repaired this unit, do you have any photos of the side panel removed showing where the plumbing is. I have investigated the difference between the comfort and plus unit and it looks like an extra tee in the circulation line. Every other part number is identical. I just cant wrap my head around how the hot water loop circulates to the taps if there are 2 tees in the part i circled. It seems the flow of water would take the path of least resistance and avoid the hot water taps.
