04-23-2022, 04:30 PM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
Truma AquaGo Installed
I just had a Truma Aquago installed in our 2022 25’ RBT replacing the Girard that came with the trailer. I decided to go with the XS black exterior door. It turned out great and I like the look. We were able to fish the wire from the water heater to the control unit in the bathroom replacing the Girard control panel so it looks stock. Unfortunately it will be a few weeks before we can use it but I am looking forward to it.
04-23-2022, 08:48 PM
2022 30' Flying Cloud
2018 27' Tommy Bahama
2016 23' International
Peachtree City
, Georgia
Nicely done! Love the way you were able to use the existing opening/panel for the Girard. It definitely gives a stock look. I made the upgrade earlier this month and we are extremely satisfied with the outcome.
Airstream should look into making the switch to Truma stock on these units or atleast offer the Truma as an upgrade option.
06-09-2022, 11:33 AM
2021 25' Flying Cloud
Willmar
, Alaska
I want to do the exact same upgrade to our 25' RTB! Thanks for pictures... Everything fit just fine? No modifications? Gas line was same size?
06-09-2022, 01:57 PM
2015 30' FB FC Bunk
Golden
Everything went in nicely. The storage compartment end wallboard on the left of the new Truma was moved to the left maybe an inch to allow the gas line to come in without a hard bend. Removed the original Gerard control and mounted the new Truma. This was a bit tricky. Drilled a hole in the inner wall just below the countertop inside the cabinet in line with the hole above for the control. Fished the control wire from the top hole to the lower hole. Used a piece of the flex and slid it along the wall behind the cabinet from the heater to the lower hole and pulled the control line over to the heater. Hope that made sense. Went with the small black exterior cover which also fit perfectly.
The installers were very good and receptive to my suggestion on how to run the control line so we could use the original mounting hole.
Not sure how to reorient the pictures when they come in.
2022 25RBT Flying Cloud, Dual AC, Full Awning Package, Solar and Convection Microwave.
12-06-2022, 06:46 AM
2023 25' Flying Cloud
Franklin
, Tennessee
How much did the Truma unit cost and the cost to install?
On Order 25RB Twin Flying Cloud
2016 F-150 Supercrew 4x4 SB, EcoBoost FX4
2022 F-250 XLT Supercrew 4x4, 6.2L Gasser
12-06-2022, 07:12 AM
2022 27' Globetrotter
DALLAS
, TX
The Truma runs around $2100 installed based on the quotes I received. I don't recall the breakdown of unit costs vs labor costs.
12-06-2022, 07:24 AM
Bethlehem
, Pennsylvania
Ouch! That’s a fair amount of money. I wonder if you can get a few hundred for your Girard on Facebook marketplace or eBay.
FYI for others interested in the upgrade, Truma does offer discounts at big RV shows and installs while you wait. I might do it next year at Hershey, PA.
12-06-2022, 07:36 AM
Costa Mesa
I had Truma in Elkhart install mine at the end of October. It was about $1,800 out the door. Very professional people. Picked the black door which looks fine. Goes with the black underbody. Love the unit. Have a one year old Girard unit if anyone is looking.
12-06-2022, 09:32 AM
2017 25' Flying Cloud
Longmont
Looks great and I like the black door. Did you install it yourself or have a dealer do it?
12-06-2022, 10:13 AM
DALLAS
, TX
A&P Vintage Trailer Works in Paradise, TX installed my Truma.
They fabricated a custom aluminum faceplate to make it look like an Airstream factory installation.
12-06-2022, 10:14 AM
2022 25' International
Savage
I agree with the black door look. I’m going to leave mine as is as well, seen here.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
12-06-2022, 02:08 PM
Longmont
They fabricated a custom aluminum faceplate to make it look like an Airstream factory installation. Attachment 425992
Foobar
That looks very nice. Looks like they do good work.
12-06-2022, 02:23 PM
Bethlehem
, Pennsylvania
Very nice! They could easily sell this.
12-06-2022, 02:35 PM
2021 27' Globetrotter
Saint Louis
, Missouri
Nicely done!
Nice job on the install.
What prompted you to switch water heaters? I'm presuming Truma has features/capabilities that the Girard doesn't. Example: can you take navy showers with it?
Thanks!
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
12-06-2022, 03:25 PM
Savage
Originally Posted by OrangeCrush
Foobar
I’d buy one! Wonder if they’d like to sell them?
TAC MN-6
WBCCI/VAC 11736
AIR 25979
12-06-2022, 03:39 PM
DALLAS
, TX
Don't know if they would sell the faceplate. Give Paul at A&P Vintage Trailer Works a call and ask.
They do fantastic work and they are great to work with.
12-06-2022, 03:54 PM
DALLAS
, TX
Thanks!
In case this question is directed at me...
I switched water heaters to mitigate multiple negatives for the Girard tankless.
1. Minimize wasted water when boondocking (it takes 40-50 seconds for the Girard to heat up a deliver hot water)
2. Girard heater requires a fairly high minimum flow rate to trigger the heater.
3. When trying to trickle hot water after the heater is triggered by a higher flow, the Girard will overheat and shut down as there is inadequate flow of cold water to keep the Girard internal in a safe operating condition.
Navy showers suffer from all 3 limitations above. When you shut off the shower head, the Girard shuts down and then needs another 40-50 seconds to turn on, heat up, and then deliver hot water. It's this behavior that causes the 'cold water sandwich' problem.
The Truma has a small internal tank (around a liter or so) that it can preheat. This small tank provides a hot water buffer that allows trickling hot water at the kitchen sink and also absorbs the cold water that comes as part of the cold water sandwich that occurs when you are cycling the hot water on and off (navy shower style or when washing dishes). The Truma also turns on at a lower flow rate and heats up faster than the Girard.
Now I have a brand new, never used Girard heater that I have to figure out what to do with, lol (sell it perhaps?)
12-07-2022, 06:20 PM
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake
Sad
So sad people have to spend a thousand plus to replace the pathetic Airsteam units. I know I own one and no amount of JC turning this pressure that flow this works. Unit is junk. Want our 2019 old gas electric back Airstream should be ashamed of installing a unit that gives you inconsistent hot water. Unhappy wife = unhappy life.
12-07-2022, 07:01 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Lowest bidder, not best design/solution. Classic Airstream M.O. Add to the list of things people replace on brand new trailers.
12-08-2022, 08:32 AM
Savage
It would probably cost more to retrofit back to an old style gas water heater than to reinstall a Truma. Yes, Airstream should have and should use Truma over Girard moving forward. Meanwhile, I stopped complaining, and had Truma installed. No more worries. The idea of hot water on demand is not a bad one. They just picked the wrong manufacturer. Added benefit for those with gas, my Truma and even the old Girard, make no noise regenerating at 3am either, which often woke me up. So gas was not the perfect solution either.
The Truma is about perfect for my needs, and the $2k+ was worth it. And it is the only item I replaced in my 2022 International. I am way happy with everything else, including the new 12v fridge, which is a great upgrade.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
