05-09-2014, 08:37 PM
PopHetzler
2003 34' Classic S/O
Troy
Quiet water Pump
Need to find a quiet water pump for a 2003 34ft . Any ideas? Mine sounds like a jet engine. DH
05-10-2014, 05:41 AM
1981 31' Excella II
New Market
They can be pretty noisy. An accumulator might help. The problem is with the impulse pumps is the pressure pulses radiate through the plumbing amplifying the noise. The accumulator will damp these out. We don't use the pump that much so the noise is not a big issue.
Perry
05-10-2014, 05:51 AM
2005 30' Classic
Burlington
The water pump that came with our 2005 Classic (bought used) was alway extremely noisy. If memory serves I believe is was made by "Aquatec."
After a couple of years use it failed and I bought a replacement from a local RV dealer - the make was "Shurflo.
The difference in noise level ... and water volume ..... was like night and day. We can barely hear it operate now.
I suppose it could have been that the "Aquatec" was in problems of some sort since we first got the trailer and just took a couple of seasons to fail completely.
Also, I recall that on one side (intake? delivery?) the "Aquatec" was hard-piped, whereas when I installed the Shurflo I made sure it had a foot of so of flex hose on each side and no doubt that helped a lot.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
05-12-2014, 03:28 PM
PopHetzler
Troy
Thanks for the info. I checked and have an Aquatec. Spoke with another Airstreamer this weekend and he suggested a Surflo too. I think a new pump is in my future. Was afraid I would wake up the whole camp with an early morning flush so had to walk to the park latrine. What a mess. thanks again. D. Hetzler.
05-12-2014, 03:42 PM
2014 25' Flying Cloud
Cuddebackville
, New York
The good news, from my experience, is that the noise is all inside the trailer- it's not really noticeable outside.
2019 Ford Expedition Platinum
05-12-2014, 10:16 PM
2013 30' Flying Cloud
Cincinnati
We put a Flojet Variable Speed R4515-743 into our 2013 FC 30
We replace the water pump when the AS was 3 months old. The old pump was noisy, and had an internal leak (pump cycling on every 30 seconds, and when connected to fresh water had a leak out of the FW tank overflow screen).
The more we've used the Flojet VSD pump, the more we like it. Pretty quiet.
05-13-2014, 03:26 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Mounting the pump with some sound insulation under it might help reduce the "drum effect" noise from being screwed to the wood floor in the trailer. Flex hose either side will help reduce noise. We also installed a ShureFlo air expansion tank so there is no water hammer effect when shutting off a faucet that can cause plastic or even PEX fittings to eventually leak.
05-13-2014, 07:13 AM
1996 34' Excella
Elberta
ShurFlo, or FloJet, in conjunction with the small accumulator tank will probably take care of the problem. In addition to that, I put a piece of one inch thick heavy rubber foam under the pump.
For whatever it's worth.
Larry
05-15-2014, 05:54 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Loose (unsecured) pipes will add to the noise also,
05-16-2014, 12:23 PM
2004 16' International CCD
Chicagoland
What do you make of this silencing kit from SHURFlo? It looks like the hoses are looped during installation to absorb vibration?
Amazon.com: SHURflo 94-591-01 Pump Silencing Kit: Automotive
Might this help to reduce the pump's noise or is it just a gimmick? Would there be any issues with installing this in conjunction with an accumulator?
05-16-2014, 12:39 PM
Salem
Hi, I made my own flexible hoses because I wanted them longer for looping and needed angled ends to fit my water pump. I added an accumulator later. All is good now.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
05-16-2014, 12:43 PM
Salem
Hi,
With accumulator.
05-16-2014, 01:07 PM
PopHetzler
Troy
I'm going to try it all. Flojet vs Shurflo? Comments/opinions?
05-16-2014, 03:20 PM
1994 30' Excella
alexandria
, Kentucky
I did the same as robertsunrus except the use of insulation around visible pipes and under the pump. We use the pump quite a bit this fix works well.
Steve, Christy, Anna and Phoebe (Border Collie)
1994 Classic 30'11" Excella - rear twin
2009 Dodge 2500, 6 Speed Auto, CTD, Quad Cab, Short Bed
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
05-16-2014, 11:59 PM
2014 31' Classic
Apache Junction
Looking at post #12 installation, does the pump have a built in filter or is there an external filter for the larger stuff in the water?
The "plan ahead for service" factory location for our water pump with built in filter that covers the area with water when opened is under two runs of duct work and wires at the bottom of the closet. We managed to get the air expansion tank in, but will contemplate the 1" rubber pad mentioned elsewhere to help with noise abatement.
There are always such great ideas to solve problems in this forum!
05-17-2014, 12:11 AM
Salem
Hi, if you look at post number 11 you will see my external filter which connects to my fresh water PEX line from the tank.
05-17-2014, 12:45 AM
1972 31' Sovereign
Benton
, Arkansas
How much noise do some of these pumps make?
Maybe I got lucky by accidentally getting one that won't wake the dead?
05-17-2014, 01:42 AM
2014 31' Classic
Apache Junction
In our 2013 25FB International, the pump was just below the pillows on the bed, so if one or the other used the bathroom at night and flushed, the other was awakened by the growl noise only inches away from their ears. :roll eyes:
In our Classic, the water pump is down the hall beyond the shower under the closet floor, which resonates like a drum. I am hopeful a rubber pad will help reduce the din to a bearable non-awakening level.
05-17-2014, 06:53 AM
1972 31' Sovereign
Benton
, Arkansas
Yea I could see how right under the bed could be an issue no doubt.
