Hi I seem to always encounter those issues that no one can figure out. That google has never encountered. It doesn’t help that our go to handyman left town. While up for any challenge, we are currently living in our 67
Caravel and out of no where the new (but never used in two years) hot water heater and pump
Aren’t working. I had two professionals come out and look and they can’t seem to diagnose it. I did order a new water pump.
The issue:
Everything plumbing wise tested perfectly prior to move in. Saw a mouse had chewed the orange ignition wire of the the suburban sw6de six gallon water heater. So we replaced and it, although working) and a week later after no use the hot water heater won’t work and the pump is acting strange.
The Hot water heater now takes 3-4 tries to light. It will Light and stay lit but as soon as you turn the water pump on it goes out. And no one can make sense of this correlation.
Shortly after many tests and someone leaving the water pump
On all day, the water pump Itself keeps periodically not working, after some rest it will work again but water pressure sucks. The bathroom sink is getting all the pressure, and the kitchen sink minimal and the shower nothing, sometimes. There is no water anywhere.
We didn’t move or use the trailer in the few weeks it went from all systems working to big fail. We did replace the wire which several others have said
Is the right one and the reader/tester said all wires on the hot water heater are hot and good. Could just be a coincidence.
Checked for leaks, not seeing any but will go deep later today and test the toilet. Water pump stays on and kind of always has lately because it sat for so long and these sensors go out often, so not certain there is a leak. Seems like there’s two different issues here??
Any smart people out there who can troubleshoot? I never realized how hard it is to find experienced professionals. Always had our go to guy. At this point I’d rather pay for a virtual call then another failed mobile rv service repair. Please help if you can! I’m so grateful. All I do is spend 12 hours a day on this and I’m getting no where. Water is life. Thank you.
