They are quite sensitive to being grossly off level. Was your fridge level all the times you had issues with it?
The other possibility is that it was just in need of a rest, so the fluids and gasses in it could settle properly. When you restarted it, it was probably nicely level, and started up properly.
Some have reported pulling the fridge out, inverting it for a few minutes, up-righting it for a few minutes, then repeating for a few cycles, "burps" the internal circulation system and restores normal operation...
They can act quite weird...
