Old 09-23-2021, 08:32 AM   #1
2020 25' Flying Cloud
Alexandria , Minnesota
Noisy Wheel Solution
A cause for the 'noise/rattle' coming from a wheel is due to not enough compression of the center cap's flange between the wheel and the rotor. When grabbing these center caps they will rotate/rattle indicating this problem. There should be no rotation of the center cap.
Solution to fix:
The center cap has a flange that incorporates 4 detents positioned at 12,3,6 & 9. If the detents are too shallow the results is this 'rattle'. I increased the depth of detents is as follows:
I drilled a 3/16" hole into the front section of a piece of hardwood and placed the 'low detents' of the cap over it. Using a 3/16" nail set and a ball peen hammer, I hit it fairly hard increasing the detent to perhaps 1/8" plus in height.
The attached pdf depicts the process.
cicho69 is offline   Reply With Quote
Old 09-23-2021, 08:41 AM   #2
"Cloudsplitter"
2003 25' Classic
Welcome Aboard...👍
I have haven't a clue about whatever it is you're trying to explain.
When I click on the PDF it just goes to all the ones on my computer.
Are you saying that the castle nut isn't tight enough?
Or possibly that the bearing cover/hub cover is loose.
Old 09-23-2021, 09:02 AM   #3
A W Warn's Avatar
2000 25' Safari
Solution to fix:
I've done a similar repair on my trailers. I used a dull cold chisel to enlarge the detent. After a few uses the stainless steel hub dust covers will rattle again.
I've even purchased new ones from Out of Doors Mart to try to stop it, but after a while they rattled too.
https://odmrv.com/catalog/index.php?...roducts_id=739
Alan
Old 09-23-2021, 09:16 AM   #4
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
A fair amount of the noise coming from the wheel assembly is the brakes and such. I have heard many drum brake setups with similar sounds. The sounds diminish considerably as the brakes are applied. Both my trailers made the same sounds since new.
panamerican is offline   Reply With Quote
Old 09-24-2021, 06:36 AM   #5
It's the chrome center cap of the wheel.
Move it and see if it rattles.
Old 09-24-2021, 06:43 AM   #6
I'm surprised at that? My other 3 have held noise free for 2 years. My center caps are of a fairly tempered metal and it takes a bit of force to increase this detent depth. Once under tension they hold well.
Old 09-24-2021, 06:51 AM   #7
"Cloudsplitter"
2003 25' Classic
OK... that splains it.
Ours fit from the inside of the wheel and have a flange and a rubber O-ring that keeps them from rattling when the wheel is tightened.
Yours must have one of the "improvements" that keep popping up.
Old 09-24-2021, 08:16 AM   #8
A W Warn's Avatar
2000 25' Safari
Mine fits from inside and has a flange between the wheel and hub.
I thought about adding rubber spacer or o-rings. Sounds like a good idea, but was wondering if it would affect the wheel to hub contact.
Thanks for sharing the info.
Alan
Old 09-24-2021, 10:27 AM   #9
"Cloudsplitter"
2003 25' Classic
No problem...👍
POI....Buy a few extra O rings.
I've had no problems, the rings came with the wheels.
My Wheel tub solution ( Aluminium, riveted ) Disco Stu Wheel Wells 6 09-02-2019 02:05 AM
Poor Wheel Well Design story and solution Pepsi Wheel Wells 15 02-08-2009 09:59 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Fantastic fans very noisy - wore out? ipso_facto Roof Vents, Skylights & Fans 5 07-17-2003 06:47 AM
Aquajet noisy? Why no more 3-way refrigs? Kistler Water Heaters, Filters & Pumps 5 11-24-2002 08:23 AM
