Old 03-17-2021, 11:06 AM   #1
Zan
2019 26' Flying Cloud
Manhattan , Illinois
Horrible Odor
I have a 2019 flying cloud. I recently noticed an odor which smelled electrical or a burning smell. I cleaned every storage area and could not find where it was coming from. That night the smell was so bad it woke me. I called the dealer to set up an appointment and I have to wait 5 days. The smell seems to have permeated the trailer and Iím concerned for my health. Any ideas what this could be?
Zan is offline   Reply With Quote
Old 03-17-2021, 11:27 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard👍
More info...what's on? furnace?, water heater, are you on shore power? lead acid, AGM, Lithium batteries?
A sulfur like smell indicates overcharging with lead acid batteries. Un-plug shore power.
Old 03-17-2021, 11:44 AM   #3
Zan
The HP was on, and I shut it down that night. Water heater off, on shore power and disconnected it yesterday but it didn’t seem to help. Lithium batteries and smelled the area but no smell. Heat seems to aggravate the odor as I used the stove and it seemed to stir it up.
I don’t have the noxious odor I had in the night, but sometimes I believe I can get whiffs of it at the back of the trailer. I have a rear bedroom
Old 03-17-2021, 01:08 PM   #4
Long Island , New York
A dead mouse etc. hidden somewhere? Suggest getting someone with a very good nose to "sniff it out" in all the hidden storage spaces, under the bed, etc..
Are your holding tanks empty and reasonably clean, or at least treated with chemicals for smell? Both the black and grey tanks may need help, depending on the circumstances.
More detailed clues would help IMO. Are you in Illinois and using the trailer? On the road? Is the trailer winterized, in storage, being used, etc. etc.?
Welcome to the forum.
Let the music lift you up . . .
OTRA15 is online now   Reply With Quote
Old 03-17-2021, 01:24 PM   #5
Zan
I have been in Arizona since last November. I have checked everywhere for rodents and found nothing. I have even snapped pictures of all areas open but impossible to see into, even the vents in the ceiling.
I keep on top of holding tanks and always use Happy Camper.
I open the windows and vents during the day (vents open at night if itís not below 45), and it seems to kick up the burnt smell.
Old 03-17-2021, 01:52 PM   #6
Any unusual vibrations when the heat pump is on.
I ignored it once 'cuz it wasn't to bad...mistake. In Spring when I turned it on again...stink, dead mousey critter.
Too bad, we can guess it for you, but we can't smell it for you.🥴
Good luck...
Old 03-17-2021, 02:32 PM   #7
Zan
I canít imagine a dead mouse would smell like something burning, could it?
Old 03-17-2021, 04:11 PM   #8
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Electrical Burning Smell location
If electronic smells, first would check closer with nose and visual for high heat burn / discoloration on the high current devices which would have the likely tendency to generate higher heats to sear electronic components and circuit boards: In order of likeliness assuming its not the common dusty heat strip stinking in the Dometic AC...
Converter, Inverter, Subwoofer, AM/FM Radio, TV's, water heater electronics, power strips, any fan motors which coils could heat and short (if you have any/all of these items). Possible any added device plugged into power ?
One thing about electrical burn smells is they stay for some time on the effected area and you may be able to pick up the smell when zeroed in at the source of issue.
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2020 GMC Sierra Denali Diesel 2500 4X4 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Old 03-17-2021, 04:15 PM   #9
Probably not, but he was in the mouse wheel and sure did stink when it cycled on. 🤢
Old 03-17-2021, 04:22 PM   #10
Good suggestions . . .
Borrow a dog or cat and let them sniff it out . . . . . . ?
Old 03-17-2021, 04:45 PM   #11
Steamguy's Avatar
2019 27' International
Washougal , Washington
Ya know.... Not so very long ago I had a SOB trailer that had a kink in the flexible duct that they use for the furnace. It restricted the airflow through that one leg, and the duct piece got HOT! And boy did it stink. Stink didn't go away for a long time.
This sounds so close to that, it sure makes me wonder. Can you have a look at the furnace itself and in the cabinets where the propane furnace ducts run, and check for kinks...?
Whee! Post #200 of mine, sure hope it helps.
Steamguy
2019 International Serenity 27 FB
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 03-17-2021, 05:15 PM   #12
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Check your Air Admittance Valve (AAV) is stuck..... it's a black cap above each sink drain. If it's not working,,,,, that is the smell!
glcmranger is offline   Reply With Quote
Old 03-17-2021, 05:44 PM   #13
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
We had a mystery odor that we eventually traced down to the 120 volt circuit breaker panel. Some of the screws that hold down the wires worked their way loose. That resulted in high heat and charred insulation on the wires. So definitely inspect those.
Also, I don't know if your model has a "transfer switch" or not, but if you have two different shore power sockets on your trailer, you have a transfer switch, and you should check the connections on it as well (if you have one, it is probably right on the back of your circuit breaker box).
SSquared is offline   Reply With Quote
Old 03-17-2021, 07:35 PM   #14
2016 30' International
redondo beach , California
If you suspect the heat pump then don't use it.
Try a small electric heater. They work better anyway.
If the smell goes away then it might be the circuit breaker or a connection for the AC.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 03-18-2021, 02:00 AM   #15
Night owls's Avatar
2018 26' Flying Cloud
Hemet , California
Following this thread as I also have a 26ft. Keep us posted and good luck!
Night owls is offline   Reply With Quote
Old 03-18-2021, 01:10 PM   #16
Zan
Thank you all for good advice. I have checked most of your suggestions (the ones I understand, single retired woman). I will post what the problem is when itís discovered. Many Thanks!
Old 03-18-2021, 02:25 PM   #17
2019 30' International
Pennsylvania , Pennsylvania
Are you sure you don't have a sewer gas issue? Maybe a black tank vent problem or something?
I know it's been discussed as smelling like electrical burning, I just thought I'd throw that out there.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 03-18-2021, 02:35 PM   #18
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
Have you checked the pin in the break away switch at the hitch. If it has been pulled accidentally, the brake magnets can overheat/burn out and have a smell like you described.
Alan
Old 03-18-2021, 02:43 PM   #19
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
got a rodent inside stove or HP? does it smell like burning meat on grill?
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 03-22-2021, 01:13 PM   #20
Zan
Thank you all for your help with this problem. The actual cause is ďAmperage of overhead stove vent is way high overheating fan motor making noise and could stop anytimeĒ. What concerns me is when the smell was at its worst, I didnít have the fan on.
Thank you all again!
How to get rid of the horrible smell? Islander Interior Restoration Forum 9 03-17-2021 04:27 PM
Horrible weather alert east coast! Del Gurney On The Road... 24 10-27-2012 03:51 PM
Really horrible feeling in my stomach Mrs.Mod General Interior Topics 23 04-08-2012 11:30 AM
Something horrible happened to my front door's interior startrekker2001 Doors & Locks 11 04-23-2010 01:11 PM
The Mattress in my 2000 Excella is Horrible! Cracker General Repair Forum 3 06-30-2007 07:08 PM
