12-13-2016, 10:30 AM
2014 30' Flying Cloud
Tampa
Link to rivet kit
So there is a small cover over the step into the Airstream that is held with three rivets, two of which have broken.
I need to remove two rivets and replace them.
I don't want to spend hundreds of dollars in a rivet gun kit.
Anyone have a link to a relatively inexpensive rivet gun/rivet kit I can use? And links to a video on how to remove/install rivets?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
12-13-2016, 10:36 AM
2006 23' Safari SE
Biloxi
, Mississippi
Go to Lowes or Harbor Freight. No reason like you say to spend hundreds. I got my all aluminum rivets from vintagetrailersupply.com. Added them to another order so shipping did not kill me.
For video go to YouTube and search riveting.
MICHAEL
12-13-2016, 10:49 AM
Tampa
12-13-2016, 12:19 PM
2005 30' Classic
Burlington
Don't want to take the topic too far off track, but has anyone used one of the air/hydraulic rivet guns typically available for rivets up to 1/4" diam for $100 or less?
I'm sure for that price it won't be a pro version, but hoping adequate for the limited amount of use I will make of it.
I have a lot of trouble with corroded rivets under the trailer (belly pan) most likely due to road salt / water getting up inside the belly pan.
I expect to have more of this work to do when we get south this winter, and will take along some tools to be ready for it!
I plan to start using larger rivets - probably 3/16" D, and imagine they could be more of a squeeze with a hand gun - plus I have some arthritis in my hands which doesn't make it any easier!
The job might a a whole lot more pleasant when lying under the trailer if I bring a small compressor and buy an air riveter - if they are any good!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
12-13-2016, 03:02 PM
They're great, up to 5/32 or so. Still have a beat up Harbor Freight model I got for less than $50. Thousands of rivets. Needs routine maintenance only.
12-13-2016, 04:29 PM
2005 30' Classic
Burlington
Thanks for the feedback! Did you not have luck with larger rivets? I was thinking to use 3/16" for the belly pan to replace the 1/8" oes that just dont seem to last.
The rivet gun I am looking at is supposedly rated to use up to 1/4" and comes with noses for four rivet sizes.
On sale here in Canada right now at "Princess Auto" our equivalent of
"Harbor Freight" and "Northern Tools" for $59, 40% off their regular price - I'll go get me one tomorrow!
Brian.
2005 Classic 30'
12-14-2016, 03:08 PM
1998 34' Limited
Lawrenceville
I have used the Harbor Freight air/hydraulic version for major skin repairs (5/32" olympic rivets) and with hundreds of 3/16" rivets as well. It works just fine. I have not yet used it with 1/4", but I am confident that it will work. Larger rivets just require slightly more force which would be more of a function of air pressure than anything else. I have used the 3/16" large head rivets for belly pan attachment with great success. Fastenal has them available.
12-17-2016, 06:31 PM
Tampa
Link to rivet kit
So my first experiment trying to rivet something was a bust. The cheap gun I bought at Amazon was not grabbing the rivets, and I decided to take it apart.
Note to self - cheap rivet guns are not adjustable.
Apparently the spring was not seated right, and once I reseated it the gun started grabbing the rivets, but I lost a small part that held the gun together. I was still able to rivet some, but the size rivets that came with the gun were too small.
So I learned something new. The rivets have a "grip" length, which is essentially how long they are, and they come in different sizes.
What size do I need? I have no idea.
So I went to Lowes intending on buying some regular screws to get this over with. An attendant asked me if I needed help, and I said "yes, where do you have your rivets?"
Not sure why I did that.
So I found a new rivet gun. Still cheap ($20 instead of $12) but it did did not include any rivets. There was a cheap variety pack with three grip lengths - 1/8", 1/4" and 1/2". They were all 1/8" diameter. The diameter didn't bother me as much, as I can make the hole bigger if I need to, but I think 1/8" is fine.
So, I'm headed back to my trailer to try this again. Wish me luck!!!
12-17-2016, 06:40 PM
2006 23' Safari SE
Biloxi
, Mississippi
Do the rivets you bought have steel or aluminum shafts? The steel rust.
MICHAEL
12-17-2016, 07:10 PM
2019 27' Flying Cloud
Kansas City
SUBSCRIBING. Have a few popped that I will attend to when we thaw out in March.
Piggy Bank
12-17-2016, 07:52 PM
Tampa
The package had both. But I obviously ignored the steel ones.
1/4" grip worked like a champ. The guard cover at the foot of the main door is once again secure, and all is well with the world. Now I'm looking for something else to rivet....
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
