Old 12-17-2016, 03:30 PM   #1
Port Charlotte , Florida
Empty trailer weight
Has anyone gutted their airstream and then weighed it? I am planning on gutting my 1971 31 foot Land Yacht and am trying to get an idea of how much it will weigh empty. I plan on bringing it to a weigh station once gutted but would like a general idea of how much all of the original interior will take off of it. The inside panel of the door says the trailer weighs 7,600 some odd pounds as is right now. Any input is appreciated. Thank you
StreamRoller is offline   Reply With Quote
Old 12-17-2016, 06:41 PM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Vintage Trailer weighs sheet
They say a '71 31' weighs 4910lb dry...
If you mean 'really' gut it you'll have 100lbs of copper pipe, another 100 in plumbing fittings, 100lbs of wiring, 100lbs of fiberglass insulation, 100lbs of carpet and tack strips, 100lb for the Dometic fridge, 175lbs of interior liner & belly pan sheet aluminum... subtract another 70 for battery, 35 for the Univolt converter, anyhow... you get the idea.
Interested what the scales folks tell you.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Wabbiteer is online now   Reply With Quote
Old 12-17-2016, 07:17 PM   #3
1976 31' Sovereign
Utica , Ohio
I am doing a frame off restoration of a 31 ft 1976. frame, tires and axles weighed 1350 lbs at the local feed mill. fabricated new frame out of 1/8x2x6 steel tubing. i did not reweigh new frame. calculated wt approx 1750.
SILVER BEE is offline   Reply With Quote
airstream soverign 31' travel trailer empty 1977 eBay Watch Airstreams on eBay 0 09-13-2013 10:20 AM
Airstream 1958- -26ft overlander trailer-interior empty-clean eBay Watch Airstreams on eBay 0 06-16-2012 06:10 PM
Weight about empty 31' Airstream Gaël General Repair Forum 3 08-13-2010 02:36 PM
Hitch for Empty trailer soldiermedic Hitches, Couplers & Balls 5 04-21-2007 07:25 PM
? Empty Weight -- '84 Excella 34' ? TOM CRUMP Our Community 3 05-04-2006 08:30 PM
