-   -   Link to rivet kit (https://www.airforums.com/forums/f44/link-to-rivet-kit-160455.html)
FCStreamer 12-13-2016 10:30 AM
Link to rivet kit
So there is a small cover over the step into the Airstream that is held with three rivets, two of which have broken.
I need to remove two rivets and replace them.
I don't want to spend hundreds of dollars in a rivet gun kit.
Anyone have a link to a relatively inexpensive rivet gun/rivet kit I can use? And links to a video on how to remove/install rivets?
AWCHIEF 12-13-2016 10:36 AM
Go to Lowes or Harbor Freight. No reason like you say to spend hundreds. I got my all aluminum rivets from vintagetrailersupply.com. Added them to another order so shipping did not kill me.
For video go to YouTube and search riveting.
FCStreamer 12-13-2016 10:49 AM
Thanks for the YouTube tip.
https://www.youtube.com/watch?v=bpyPQ0kvGyo
https://www.youtube.com/watch?v=nozX56N8TX0
https://www.amazon.com/TEKTON-6555-R...ords=rivet+gun
Wingeezer 12-13-2016 12:19 PM
Don't want to take the topic too far off track, but has anyone used one of the air/hydraulic rivet guns typically available for rivets up to 1/4" diam for $100 or less?
I'm sure for that price it won't be a pro version, but hoping adequate for the limited amount of use I will make of it.
I have a lot of trouble with corroded rivets under the trailer (belly pan) most likely due to road salt / water getting up inside the belly pan.
I expect to have more of this work to do when we get south this winter, and will take along some tools to be ready for it!
I plan to start using larger rivets - probably 3/16" D, and imagine they could be more of a squeeze with a hand gun - plus I have some arthritis in my hands which doesn't make it any easier!
The job might a a whole lot more pleasant when lying under the trailer if I bring a small compressor and buy an air riveter - if they are any good!
Brian.
markdoane 12-13-2016 03:02 PM
They're great, up to 5/32 or so. Still have a beat up Harbor Freight model I got for less than $50. Thousands of rivets. Needs routine maintenance only.
Wingeezer 12-13-2016 04:29 PM
Thanks for the feedback! Did you not have luck with larger rivets? I was thinking to use 3/16" for the belly pan to replace the 1/8" oes that just dont seem to last.
The rivet gun I am looking at is supposedly rated to use up to 1/4" and comes with noses for four rivet sizes.
On sale here in Canada right now at "Princess Auto" our equivalent of
"Harbor Freight" and "Northern Tools" for $59, 40% off their regular price - I'll go get me one tomorrow!
Brian.
fwjumper 12-14-2016 03:08 PM
I have used the Harbor Freight air/hydraulic version for major skin repairs (5/32" olympic rivets) and with hundreds of 3/16" rivets as well. It works just fine. I have not yet used it with 1/4", but I am confident that it will work. Larger rivets just require slightly more force which would be more of a function of air pressure than anything else. I have used the 3/16" large head rivets for belly pan attachment with great success. Fastenal has them available.
FCStreamer 12-17-2016 06:31 PM
Link to rivet kit
So my first experiment trying to rivet something was a bust. The cheap gun I bought at Amazon was not grabbing the rivets, and I decided to take it apart.
Note to self - cheap rivet guns are not adjustable.
Apparently the spring was not seated right, and once I reseated it the gun started grabbing the rivets, but I lost a small part that held the gun together. I was still able to rivet some, but the size rivets that came with the gun were too small.
So I learned something new. The rivets have a "grip" length, which is essentially how long they are, and they come in different sizes.
What size do I need? I have no idea.
So I went to Lowes intending on buying some regular screws to get this over with. An attendant asked me if I needed help, and I said "yes, where do you have your rivets?"
Not sure why I did that.
So I found a new rivet gun. Still cheap ($20 instead of $12) but it did did not include any rivets. There was a cheap variety pack with three grip lengths - 1/8", 1/4" and 1/2". They were all 1/8" diameter. The diameter didn't bother me as much, as I can make the hole bigger if I need to, but I think 1/8" is fine.
So, I'm headed back to my trailer to try this again. Wish me luck!!!
AWCHIEF 12-17-2016 06:40 PM
Do the rivets you bought have steel or aluminum shafts? The steel rust.
Piggy Bank 12-17-2016 07:10 PM
SUBSCRIBING. Have a few popped that I will attend to when we thaw out in March.
FCStreamer 12-17-2016 07:52 PM
The package had both. But I obviously ignored the steel ones.
1/4" grip worked like a champ. The guard cover at the foot of the main door is once again secure, and all is well with the world. Now I'm looking for something else to rivet....
