05-29-2023, 01:29 PM
2017 23' Flying Cloud
Waukesha
, Wisconsin
Broken wires at brake drums
I’ve had some issues with braking on the curb side of my coach for a while now, but was attributing it to needing to reset the brake controller which seemed to remedy the problem. Today however I was underneath taking care of some rust and noticed that both curb side wheels have gray wires severed at the drum! Yikes! I assume these wires activate the brakes so it probably means I haven’t had braking on that side for a while now. Has anyone else had this issue?
05-29-2023, 01:53 PM
Oswego
Perennial issue with all trailers with electric brakes.
Sent from my SM-S901U using Airstream Forums mobile app
-Rich-
05-29-2023, 02:33 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Yes. Has happened to me several times. Big wire connects to little wire and no real way to make the connection good. Search Amazon for heat shrink connectors with step down sizing and buy a ratcheting crimper for then. I put a short intermediate wire in mine to help with the wire size change.
05-29-2023, 02:57 PM
2019 25' Flying Cloud
Houston
I fixed this same thing on my brother's trailer last week and several times on a carhauler I own.
05-29-2023, 03:23 PM
Waukesha
, Wisconsin
OK - thank you for the replies. I also read the similar posts that showed up on earlier threads. There seems to be good lengths hanging out to do a repair myself so I’ll try it and see how it goes. Based in all the responses that reference this is a common problem, it seems like a more reliable system could be configured in the first place! Ha! Anyway - thanks again.
05-29-2023, 03:45 PM
Oswego
My memory has faded...but there is a very flexible wire made for vibration resistance. You might splice a section in. It helps a lot with longevity. Someone help me out here with th name of that wire.
I did the swap on my old trailer and never had a break again.
Btw, you might want to carry a selection of connectors and a crimp tool along in your travel kit. There's always a need for them.
-Rich-
05-29-2023, 03:56 PM
2008 22' Safari
Spicewood (W of Austin)
multi-strand or “stranded”
05-29-2023, 04:03 PM
Oswego
Yeah, there was more to it than that. It had a real rubbery insulation. Silicone maybe, but didn't really feel like it. This was some 20 or 30 years ago. It reminded me of a fusible link, but was wire.
-Rich-
05-29-2023, 04:20 PM
Moderator dude
1966 26' Overlander
Phoenix
On a previous trailer I used a plastic conduit. Similar to the attached picture except it was black. Worked to keep out most of the things that might cause damage.
However if the wire caught on something and got yanked the conduit would not help there.
Action
05-29-2023, 08:29 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
I’m going to try these with shrink over the top.
05-29-2023, 09:04 PM
Oswego
Originally Posted by sheriff1
Get the heat activated glued shrink. Water does get in these connections whatever you use.
-Rich-
05-29-2023, 09:06 PM
1994 25' Excella
Waukesha
, Wisconsin
Seems like the big issue is not how you make the wire connection, it's frequent inspection to make sure that the wires have not snagged on something and gotten pulled out. I'd rather have the connection be the weak link in this event - make the connection too securely and instead of pulling out when snagged it will rip the wire apart and have it not be easily repaired.
On my new axles I incorporated a few well placed zip ties to hold the cable tighter against the axles, moving the loop for movement of the axle a bit higher up. It can still allow the axle to move without pulling on the wires, but the loop is not so susceptible to being snagged. It just takes one well-placed branch at a camp ground to snag on the wires and disable the brakes.
Richard
11018
05-30-2023, 07:49 AM
2019 25' International
Providence
, Senior Electrical Engineer
05-30-2023, 08:07 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by dznf0g
Yep...even after JC replaced our axles they couldn't bring themselves to route the wires correctly...
05-30-2023, 08:19 AM
2008 22' Safari
That almost looks like mouse-chewed wires.
05-30-2023, 08:36 AM
Oswego
Looks like a rub-through to me.
-Rich-
05-30-2023, 08:49 AM
2005 25' International CCD
Westlake Village
Found…. Broken brake wires !!
Just back from a 3week 3k mile southwest US round From the start, noticed dramatically lower braking to the point having to increase the brake gain to 10!!
This was just after a fresh bearing repack before trip. (Diligently avoiding contaminating the drums from grease on this 25ft 2005 Intl. )..
Thank goodness for diesel breaking option which saved the trip.
Back home, doing a star wheel brake adjustment (all we’re off) also found 2 brake leads severed on different wheels. One had snapped off right at the grommet entering the brake assembly. Obviously all are becoming brittle with age. Or possibly the I-40 potholes?
The smaller white sheathing hardened and cracked exposing bare wire which corroded to a disconnection.
While repairing, the other lead easily pulled out from the large to smaller factory butt connection ! WOW !
Repaired all for now soldering, crimping and using Goop Marine to reinforce the brittle flexing areas but seriously considering replacing all 4 with fresh “self adjusting” Dexter brake assemblies for the combined benefit and fresh flexible leads.
Very little confidence in this Original factory chance discovery.
05-30-2023, 09:02 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Almost not...
They would have had to hang on like crazy on the 400mi trip back to homebase.
First thing I did when we got back from JC.... remove all wheels ck all mounts
and torque lug nuts..."trust & verify".
05-30-2023, 09:16 AM
Moderator dude
1966 26' Overlander
Phoenix
HD sells aluminum, flexible, electrical-conduit. I suppose one could route the wires thru some of that and secure the ends of the conduit firmly to adjacent structure.
Using a metal conduit or sheathing can be an issue. If the wire connection were to come apart or the wire were to chafe somehow, that is creating a short on a circuit that can carry a lot of current.
If using a metal covering, use a fuse or breaker in that circuit to prevent a spark or fire.
Action
