I am apologizing ahead of time for those who recognize this post is redundant, but in case it is not:
Originally Posted by Eagle & Bear
Thanks everyone for the responses. Not sure what two Ds on the front axle and two Es on the second axle will or will not do to our AS. This is the second time that Discount Tire has gotten the tire load range wrong. If I want to have them replace the two Es they would put on a pair of Carlisles. Last time I used Carlisle the tire tread became cupped after 500miles. I think I will go with the Ds on the front and Es on the rear. Since this is fairly well documented, if I break a frame I will call Discount and see if they will pay for frane failure.
Sorry, but the opposite is true. You can replace LR D tires with LR E tires and use them at the same pressure - and they will be functionally equivalent. There is no difference in load carrying capacity and it is the inflation pressure that matters most with regards to a tire's spring rate - hence there is no additional problems caused by using a higher load range. (which is why Goodyear now offers LR E's, where they used to have LR D - and Discount Tire knows that.)
