Here is my opinion and disclaimer: This coming from someone who has only owned one RV, and I owned it for a little over a year... but have pulled it over ten thousand miles since June 5th.
I installed the TST 507 TPMS system at the beginning of our trip, a non pass through system. This is the only type I have ever had.
I purchased new GYE tires at the start of the trip. I only added air once about a two months ago, not because there was an issue with the tires but because of altitude and temperature changes along our route.
With that said here is what I think: If you have tires which slowly loose tire pressure and need to be topped up regularly, or if you are the type of person which feels the need to constantly correct your tire pressures due to changes in altitude and or temperature buy the pass through system.
Having the non pass through system for me, has been fine.
(BTW- If you do purchase the TST system get the repeater, I didn't, and I do regret that. I will be buying one before next years trip.)
