09-02-2020, 01:47 PM
Orlando
Bumps on Tire Wall
Need some advice,
We are on our first trip( 2500 miles)on our Airstream Globetrotter 30’ 2020. Made it to Jackson, WY. I was checking my tires and found these bumps on 3 of the 4 tires.
I called the coach net and sent them the below photos and advised to change all the tires.
I called Airstream and emailed them the photos, and they assured me that these are normal structural elements in the tires, and they are safe to drive
I would like to have your advice if it is safe to travel with these tires!!
09-02-2020, 01:57 PM
2018 25' International
Slidell
, Louisiana
The bumps you noticed are a consequence of the Endurance sidewall design. Airsteam is correct. It is normal and typical for these tires. For other tires, not so much so I understand the concern and confusion.
09-02-2020, 02:16 PM
2019 19' Flying Cloud
Canyon Country
I seen those similar bumps on many tires. somewhat normal. if the bump gets worse, you know tis not normal
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
09-02-2020, 02:24 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Tire Rack has a nice explanation of the indentations from manufacturing but the real issue is if you have BULGES them's bad news and commented in their post further down.
https://www.tirerack.com/tires/tiret...%20the%20tires.
"Sidewall Indentations / Undulations
Sidewall indentation
Fig. A: Vertical indentation on sidewall from rim to tread.
A common byproduct of radial tire construction, sidewall indentations/undulations are more noticeable in tires with taller sidewalls or operate at higher inflation pressures. Fortunately sidewall indentations are a cosmetic condition that does not affect the performance of the tires."
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard👍
Indentations.....ok.👍
Bumps....not so much.👎
09-03-2020, 10:04 AM
2019 25' Flying Cloud
North-Central
Had same. Manufacturing artifact confirmed by my Goodyear guy.
09-03-2020, 10:19 AM
2018 27' Flying Cloud
Erie
, Pennsylvania
Same here
Mine are all the same but if I could suggest to weigh/scale your trailer and use the Goodyear inflation chart to adjust your tire pressures.
EXPERIMENTAL based on untested ideas or techniques and not yet established or finalized
Rick & Becky #28279
2018 FC27FBQ
2021 RAM 2500 Hemi 6.4
KD3OBX 146.520
09-03-2020, 01:53 PM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
Normal occurrence..
09-03-2020, 02:50 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Undulation OK. Bumps are the start of tread separations. Get new tires.
guskmg
09-04-2020, 08:04 PM
Moderator dude
1966 26' Overlander
Phoenix
Not limited to any specific tire manufacturer. Can be found on many other tires manufactured by many different companies.
This is a result of the tire manufacturing process and does not negatively impact the performance of the tire.
Action
10-17-2020, 08:46 AM
2021 25' Flying Cloud
SF Bayarea
bump on sidewall
Just did our first trip in our FC 25FB. Round trip was about 175 miles. Noticed a bulge on the front passenger side tire of the trailer when we dropped it back at the dealer for storage. Replacing the tire. Disappointing on a new unit. Plus our tankless water heater leaked...nothing's perfect and we still love it!
10-17-2020, 09:52 AM
Somewhere
, South Carolina
Bulge in sidewalk going out or indentation going in?
10-17-2020, 12:16 PM
SF Bayarea
Ours was bulging out on the sidewall
10-17-2020, 12:20 PM
Somewhere
, South Carolina
Mike,
Yup bulging out, pursue with warranty. Happened to me on a Marathon years ago.
Good to catch it and get it taken care of.
Gary
