04-22-2017, 06:24 PM
Valley View
1 or 2 AC units?
Hello all...I'm currently getting ready to purchase a 2017 FC 30ft bunk. The unit I am currently looking at only has 1 AC. With living in Texas will I be ok with keeping it cool? I feel like with the ducted system now I will be fine, but would like your opinion?
Thanks MUCH!
04-22-2017, 06:59 PM
2014 30' Flying Cloud
Tampa
I'd recommend two. 30ft and Texas.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
04-22-2017, 07:18 PM
Granbury
For sure get 2. 30 ft...I wouldn't get a 25 ft without 2! Trust me as I owned a 30 Classic and sometimes with both it was hard to keep cool.
You will burn up in the Texas summers with just one a/c...even ducted.
04-22-2017, 09:03 PM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
Two AC units plus full awning package.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
04-23-2017, 04:34 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We had a 2013 25FB International Serenity with a full awning package and 15,000 BTU A/C and it was hard pressed to stay cool in the Arizona heat. Our Classic has both A/C units (13,500 BTU in back and 15,000 BTU in front) along with the full awnings set and is able to keep the unit to a 20 degree temperature spread between inside and outside out in the sun, which is only what the manufacture's claim the equipment should be able to do.
Our much smaller 2015 23D International Serenity with full awning package can cope in hot weather with it's 13,500 BTU A/C.
04-23-2017, 11:16 AM
2015 25' Flying Cloud
Hahira
, Georgia
My 25 FC has 2.
From my Pecan Tree
04-23-2017, 11:52 AM
1990 34' Limited
2013 27' FB International
Conroe
I highly recommend 2 AC units.
04-23-2017, 11:54 AM
2022 Atlas
Homosassa
From a Florida perspective as others have noted, get two. Highly recommend the awning package as well.
04-23-2017, 12:15 PM
1977 27' Overlander
1996 34' Excella
Florida Panhandle
I agree with this if you plan to spend any time in warmer climates.
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
04-23-2017, 01:31 PM
2016 28' International
Albuquerque
, New Mexico
50 amp service is now the default standard on all 30' models, so you'd want to have a really sound reason to go for the 30 amp option.
The one mistake we made was not getting the 50 amp upgrade on our International 28. I was concerned about the weight of the 50 amp cord since I am sometimes on my own, and our salesman assured us we'd be fine with just the single air conditioner since we were also getting the full awnings package. Most of the time we're fine, but there were a couple of longer trips (including one to the factory last year for warranty work), where we were absolutely miserable.
You can plan trips during cooler seasons, but sometimes temperatures are unseasonably hot. Two small portable fans inside the trailer have helped, but only a little.
I absolutely agree with the recommendation of others here-- get the two ACs and the full awnings package!
04-23-2017, 01:56 PM
2010 30' Flying Cloud
Pearland
I agree that 2 AC units are needed in South Texas. I have a 30ft. 2010, Flying Cloud with only 1 AC. I recently read in Trailer Life of someone retrofitting a Coleman-Mach AC roof unit in the space that the rear Fantastic Fan was installed. The power requirements were such ( about 7.5 amp as I recall.) that both AC's could be used on 30 amp service proved nothing else was in use. I would like to use the rear ac to cool the bedroom for sleeping and as an auxiliary with the main unit if it got way too hoe inside. Has anyone done this? Does anyone have experience with the Coleman-Mach AC unit?
04-23-2017, 06:58 PM
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
C'mon up to Cooler Canada.
My 30' FC has one AC, (ducted) and it's fine.
And Ontario has nice fishing, and great scenery, good everything, except Red traffic lights; (but you'll have to share it with God. It's his country)
04-23-2017, 07:20 PM
2012 30' International
Ferndale
Our 30' International would not be even close to comfortable above about 85 degrees without two A/C units!
04-24-2017, 12:49 AM
2016 27' Eddie Bauer
2009 34' Panamerica
2009 34' Panamerica
Sarvvik
, FINLAND
Get two AC-units. Just a side note, that in my opinion, Airstream's AC-units are quite noisy, but I don't think they're that much options for that.
04-25-2017, 05:51 AM
Ferndale
I totally agree with the noise issue with Airstreams. I am not sure if the newer ducted ones have remedied this but on our 2011 the heat pump is so noisy we can't watch TV. Couple that with marginal insulation, single pane windows and no sealed belly and you end up running the heat or A/C a lot more than a 4 Season trailer like an Artic Fox or some of the nicer 5th wheels. Price you pay for the "coolness factor" of an Airstream.
04-25-2017, 06:05 AM
Mantua
, Ohio
Nothing keeping you from buying a four season trailer, enjoy. My opinion, if you're not suffering some while camping, you're missing one of the reasons you go? When the time comes that my trailer has to be a smaller version of my home, I'll stay home.
04-26-2017, 07:49 AM
Ferndale
I did plenty of suffering when I used to back pack all over the Sierras and Cascades. Got wet, cold, mosquito bit, chased by black bears etc I still tent camp when I'm white water rafting or the occasional back pack to high country lakes but to say you need to suffer a little to be camping just defies logic to me. My main point that for a $100,000 travel trailer you would think there would be double pane windows, heat ducts in the floor, sealed and heated water and holding tanks and drain valves and a quiet A/C and heat pump. There is a lot to like about my Airstream and my wife and I enjoy our time on the road, but when we woke up to 18 degrees one day in Utah you start to see some shortcomings.
04-26-2017, 08:40 AM
Tampa
And enough are paying three times as much for the pleasure(?) that Thor is laughing all the way to the bank.
(and I'm one of their fans, but maybe more realistic.)
Is Hartmann luggage worth the extra cost?(Knowing Hartmann is owned by Samsonite.) Harley Davidson? Mercedes? Gucci?
"Pay no attention to the man behind the curtain."
04-26-2017, 09:55 AM
2007 25' International CCD FB
Northridge
Damn and I thought it was cold when I woke up in Quartzsite and it was 41 inside the trailer Compared to your 18 degrees I was in a heatwave
LilNomad
04-26-2017, 11:52 AM
2015 30' FB FC Bunk
Golden
Agreed!!! I wanted a home on wheels. Why sped the big bucks otherwise. Really!
