1963 19' Globetrotter
China Grove
, North Carolina
Screen under refrigerator
63 globetrotter has screen wire under the refrigerator and an additional piece in the belly pan. Is this original and necessary? There are no vents on access door
My '67 GT had both those screens. Both were 1/4 inch galvenized mesh presumably to keep the critters out.
I had a bigger problem with wasps so make sure to check the opening on the roof under the cover. I had to put a piece of finer screen up there as well.
Tom
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
When the refrigerator is running on LP, it’s needs a chimney affect air flow (in from the bottom out through the top) for the CO to be drawn outside. For a proper setup the intake vent should be lower than the burner.
Judging a person does not define who they are, it defines who YOU are.
