01-22-2023, 06:30 PM
#21
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
The exhaust plenum to channel the propane exhaust from the absorption refrigerator will no longer be needed. Mine appears to be in reasonably good condition and I would be happy to donate it to anybody that needs it. Here is a photo.  The RM2510 refrigerator has a volume of about 5 cubic feet. The absorption parts take up a fair amount of space behind, under and with in the refrigerator. I calculated it to be about 2 cubic feet. This means that after all the absorption stuff is removed that the refrigerator box can be enlarged by about 2 cubic feet to increase the total fridge volume from 5 cubic feet to 7 cubic feet.Basically this can accomplished by moving the rear wall back about 4”. Here are some photos.
01-22-2023, 06:40 PM
#22
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Here are the photos.
01-22-2023, 06:42 PM
#23
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
#24
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
01-22-2023, 07:01 PM
#25
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Dometic rm2510 absorption fridge conversion to 12v compressor
By converting the RM2510 from absorption to a compressor fridge, I believe there will be the following numerous advantages:
1. An increase in the fridge volume from 5 cubic feet to 7 cubic feet.
2. More insulation around the refrigerator.
3. The refrigerator installation is now permanent. No need to ever remove it since it is just an insulated box. All the functional parts are in the wall cabinet.
4. It should be much more reliable since the equipment is easily accessible and can be easily cooled since it is right next to the exhaust vent. Here is a photo.  Merry
01-22-2023, 07:05 PM
#26
1988 32' Excella
Robbinsville
, New Jersey
Originally Posted by TouringDan
My original plan was to install an Isotherm 2012 with a 32” long evaporator plate. The plate would be installed on the rear vertical wall that is 32.5” high. About 6” of the evaporator plate would be installed on the rear wall of the freezer that is 6” high and the other 26” of the plate would be installed on the back wall of the refrigerator section. Logic tells me that if I did it this way, the freezer and fridge would be at the same temperature.. I am now thinking that I need to install an Isotherm 2017. This has an evaporator plate that is 39” long. 26” of the plate would be installed against the rear wall of the refrigerator section and 13” of the evaporator plate would be installed in the freezer. For this to work the evaporator plate would need to be bent into an L shape at the top. 6“ of the evaporator plate would be against the rear wall and 7” would go along the top in the freezer. I think this would insure that the freezer would be significantly colder than the refrigerator.
Here is a photo of the freezer section.
Dan Attachment 427442
Are you sure the evaporator plate can be bent without damage?
It looks like the 2012 picture you posted has tubing going through it for the coolant to go through.
01-22-2023, 07:35 PM
#27
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
I thought of 2 more advantages.
1. The empty fridge box weighs 35 lbs. The absorption equipment weighs 35 lbs and the compressor equipment only weighs 20 lbs. So the compressor fridge that is 2 cubic feet larger than the absorption fridge will weigh 15 lbs less.
2. Since there will be no need for the outside access door this can be eliminated and just install a patch over the access hole. Another Tradewind owner may need the access door.
Dan
01-24-2023, 10:59 AM
#28
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Thanks for chiming in. No, I am not sure it can be bent. I thought I read somewhere that it could be bent and they do offer an L shaped evaporator plate for smaller refrigerators.
If it can’t be bent I may try to build a baffle around the upper part of the evaporator plate that is in the refrigerator section that would provide more cooling for the freezer section.
Dan
04-18-2023, 11:12 PM
#29
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Time to go camping so time to finish the conversion of my RM2510 absorption fridge to a compressor fridge. I have decided to go with the 2012 unit with a flat evaporator plate 8” x 32”. It will be installed so that part of it is in the freezer and part of it is in the fridge.
I have decided to remove the back 4.5” of the fridge and replace it with a 9” section built from polystyrene and covered with fiberglass on the outside and lined with frp (fiberglass reinforced plastic) panels on the inside. It will also contain the evaporator plate.
Here is a photo of the fridge with everything removed and ready for surgery. It was mostly all foam and plastic with some aluminum for the freezer compartment.
I made an attempt at a first cut with my circular saw but it didn’t cut deep enough.
I then tried my table saw and it cut 3” deep which was adequate except for the small section between the freezer and the fridge. I had to cut this section with my oscillating saw. The end result was finally successful- the rear 4.5” of the fridge nicely cut off.
Interesting to note that there is 3” of foam around the freezer section but only 2” of foam around the fridge section.
Next will be construction of the new 9” rear section with the evaporator plate installed and then connect this assembly to the front section of the fridge.
Dan
05-03-2023, 08:44 PM
#30
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
05-03-2023, 09:11 PM
#31
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Looking at the last photo, you see that there is nothing in the compressor fridge except for the evaporator plate and the temperature sensor- no moving parts to fail. These are all in the wall cabinet above the fridge. After I install the new fridge box I will install as much insulation around it as there is space available. I hope it will be many years before this fridge will need to be removed.
The wall cabinet above the fridge that will hold the compressor and thermostat was a bit damaged because I removed the exhaust duct that was required by the absorption fridge. Here is a photo of the damaged cabinet and the repaired cabinet.
Dan
05-09-2023, 02:29 PM
#32
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Hi Dan, Thanks for the photos - hoping you'll have more pictures as you make progress with the conversion and installation. Keep us posted.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
05-13-2023, 04:18 PM
#33
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
I have attached the new rear section of the fridge to the original front section. The original shelves were 11” deep. I will need to add 8” shelves and shelf supports to the new rear section. The total depth of the new modified fridge shelves will be 19”.
The third photo shows the freezer section.
Instead of 2” of air and some hardware required by the absorption fridge at the bottom of the metal fridge stand, I have added 2” of foam insulation. I am going to add as much foam insulation as possible when I install the fridge in our Tradewind.
Dan
05-13-2023, 06:04 PM
#34
1966 22' Safari
Fredericksburg
It looks like a new fridge. I don’t think you can add too much foam. Looking forward when you plug it in and post the results.
