Fridge not working, freezer is working
Kevin
Any chance for actual temp readings? And are you using propane or AC power to cool. How long has it been on?
The boiler serves both units, one piece that’s where the heat exchange happens but from the back of the unit.
Two things you can check. Dollar bill test on door seals. Then use hand screwdriver to make sure fridge screws are tight to boiler assy creating cooling transfer path.
Any chance a large warm item has been placed in fridge? These do good job keeping stuff cold but not so strong at cooling down a warm pot of soup or case of drinks etc.
Gary
