04-08-2018, 10:15 AM
2017 27' Flying Cloud
Greer
, South Carolina
Propane Covers
Took the propane covers off for a good scrubbing and found two spots where the bottom ribbing is eroding due to metal on metal vibration.
Additionally the toss away piece of foam that was between cover and power lift head failed at some point and left a smear of glue adhesive. Tried soaking and cleaning with Simple Green and unable to remove all the residue.
Hints on stopping the eroding metal and cleanup would be appreciated.
04-08-2018, 10:56 AM
Johnnyooo
2015 23' International
Colrain
, Massachusetts
There a number of products for removing adhesive, and other stains ...Goof Off is a product I've used which can be found in most paint supply stores...Some of the big box stores may carry it, or a similar product....
04-08-2018, 11:59 AM
1976 31' Sovereign
Oswego
As I posted before in previous forum thread, DO NOT USE GOOF ON CLEAR COAT IT WILL REMOVE COATING.
04-08-2018, 01:14 PM
Greer
, South Carolina
They meant well - no harm.
04-08-2018, 04:44 PM
Johnnyooo
Colrain
, Massachusetts
I was not aware of your previous post that said no Goof Off on Clear coat... I wasn't aware it was that strong...Perhaps mineral spirits would work....That is not so strong as to remove clear coat ...If it is, there's something wrong with the clear coat, which should be the same as your auto... Thanks for the info....
04-09-2018, 06:23 AM
Greer
, South Carolina
Aahhh no worries. I’m trying soaking with soap and water. May be a lost cause
04-09-2018, 06:26 AM
2021 25' Globetrotter
Jamestown
, Rhode Island
It depends on the clearcoating.
On a modern Airstream, one with the precoated panels, goof off is fine. I have used goof off, lacquer thinner, acetone and paint thinner on that stuff without damaging it!
Bruce
Loving our 2021 Globetrotter 25 and our 2022 Ford F-150 King Ranch 5.0!!! Plenty of payload, not even close to axel limits and it drives and rows beautifully…
04-09-2018, 09:49 PM
2007 22' International CCD
Corona
Propane Covers
Try Rapid Remover on the adhesive. I know this will NOT screw up the clear coat on a 2007 AS by actual use...
Follow with mild detergent to remove the slightly oily residue from the Rapid Remover. (Sometimes it never ends, huh?)
