I redid mine also, using an upholstery shop in Lake Havasu. I learned that there were two classes of foam density, with soft, med, and maybe two levels of firm in each. Upholstery foam which came stock and softer, meant to be used over a spring base like a couch. And boat foam meant to be used over a firm surface like wood/fiberglass as used in boat construction. This foam has a firmer level of support, so you don't sit right through it. There are different materials that foams are made from. Different manufacturers with different levels of soft, med, & firm. There is the issue of break-in too, they all will get a level softer over use.
Happy shopping, , ,
"Chip Tank" is in Westwood Ca.
