Originally Posted by Kimbrey
Hello again,
Do you Airstream owners see any corrosion et cetera with the trailers in areas where dissimilar metals are used? Or is Airstreams aluminum coated somehow to prevent this to a certain extent? Or maybe the difference between the trailers and a boat is salt water? Not sure about that. Anyway the whole dissimilar metal thing is ingrained in my head so it has me wondering about these trailers.
Well, to answer the original question, yes dissimilar metals can cause corrosion in Airstreams (SS fasteners really should be avoided unless thoroughly sealed, etc., as counter-intuitive as that seems). I suppose the difference between trailers and boats is that the trailers are not wet most the time, the water is relatively fresh (even distilled in the case of rain water), and therefore not as conducive to ionic transfer. SS fasteners, if used are generally thoroughly gooped, just to avoid creating a leak.
The newer trailers do have a factory applied plasti-coat on the aluminum which protects it to some extent, but even the vintage trailers that have been around for decades, have had the clearcoat polished off, and have had various modifications made to them (possibly with stainless screws) rarely have existentially threatening corrosion.
If you want something to worry about, consider that the skin on a trailer is .03-.04" thick, whereas the hull on your aluminum boat is...well... a lot thicker. Bumping your aluminum boat into a dock results in no damage, bumping your Airstream into a low hanging branch could result in a crumpled segment and thousands of dollars in repairs.
good luck!
