Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-19-2021, 09:04 AM   #1
Golden , Colorado
Lightbulb Wiring AC to run on generator
Hello there , I Ran a search and didn’t find what I need
I am installed a new Furrion AC manual controls (14,500 bru) into my 1972 land yacht overlander
I understand from the install thar I need to “ Routea115VACsupplywirewith ground wire from the time delay fuse or circuit breaker box to the roof opening.”
Ok so know how to do that I am pretty good with electrical
What I need to know is: after I do the above wiring what cord with male connector do I need to wire in order to run it off my generator?
I have a champion dual fuel generator with One 120V 30A RV outlet (TT-30R), one 120V 30A locking outlet (L5-30R) and two 120V 20A household outlets (5-20R) - trust Volt Guard built-in surge protector to prevent overloads
So…..
I connect the wires from the cord to the fuse “box” and then the other end will have a male end
Which one do I get?
Thanks so so much I have spent hours looking through the forums and google etc
Emmaggy is offline   Reply With Quote
Old 09-19-2021, 10:05 AM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
With a normal A/C install in a normal trailer, the wires run from the A/C unit to the breaker panel in the trailer (yes if you go back far enough it's a fuse panel). That panel routes AC power to various bits and pieces in the trailer, one being the converter / charger.
The breaker panel runs out to a socket on the side of the trailer. It likely is a 30A connector of one sort or another. Various era AS trailers used various connectors. Over the years older trailers have been "upgraded" to a variety of connectors. ( = who knows what's there now without a picture ....). That 30A hooks into your shore power cable and goes over to the campground power post.
The "easy" way to hook in a generator is to simply adapt it to the same three pin connector that the shore power cable uses. They are a standard item and Lowes or Home Depot should have both sides of the connector on the shelf.
Old 09-19-2021, 10:36 PM   #3
Golden , Colorado
Thanks Bob
There is literally nothing in my AS
It’s gutted I have the Insulation in as well as sun floor so I’m building this from ground up
Planning a solar system have purchased everything I need just need to install
So romex in conduit to fuse panel to charge controller to plug?
Old 09-20-2021, 07:10 AM   #4
Half a Rivet Short
2022 Interstate 24X
Originally Posted by Emmaggy View Post
Thanks Bob
Hi
First work out *all* of the things that will have 120V going to them. This includes stuff like outlets in the kitchen and power for an outdoor grill. It also may include power to the furnace and to the hot water heater.
Once you have a good idea of how many circuits / how many amps per circuit you can go shopping for a breaker box. It's going to have to get tucked in somewhere. It will have a main breaker for the feed from the power inlet socket and sub breakers for each of the circuits. It may well have a few "ground fault" breakers in the mix.
The normal "big decision" is 30A or 50A feed to the box. A 30A feed is going to be 30A at 120V. A 50 A feed is 100A at 120V. There are multiple "standard" plugs for each of them. You can use the fancy Smart Plug's on either or the more traditional twist locks.
The key is to get a pretty good idea of what's what before you start pulling wire.
To answer the conduit question, the typical modern AS trailer does not have any conduit in it. There is a lot of debate about the "best" way to do wire in a trailer.
Yes, there's a lot more to it than this quick snapshot. There also are a lot of threads on this stuff. There's also no shame in getting a pro involved.
Inverter install and wiring run help (2001 Excella) fventura 1997 -2001 Excella 3 09-18-2017 07:31 PM
Inverter install and wiring run help (2001 Excella) fventura Batteries, Univolts, Converters & Inverters 0 07-10-2017 07:58 AM
Inverter/Generator Run on LP judybug Generators & Solar Power 1 05-13-2010 08:47 PM
Onan generator run problem AccessMaster General Motorhome Topics 5 03-03-2007 06:30 PM
