06-05-2018, 11:24 AM
#81
2007 22' International CCD
Corona
Try using a shallow "old work" 2x4 electrical box (usually blue colored plastic) from the big box home improvement stores.
They have flanges and screw-down holder thingies on two corners to keep them in place in a hole...and are designed to install relatively easily from the front.
06-05-2018, 11:46 AM
#82
2012 16' Sport
San Bernardino
that's what I got from home depot. but there is no place to screw the box to
06-05-2018, 11:53 AM
#83
2002 30' Classic S/O
Fleming Island
Old work boxes don't screw to anything. They have arms that rotate out to go behind the wall, whatever it is. But on my trailer they were too deep.
As I said in my post above, this is what you need:
https://www.amazon.com/RV-Designer-S...8&s=automotive
or this:
https://www.rvupgradestore.com/AC-Se...-p/19-2433.htm
They have the electrified parts covered.
Al
06-05-2018, 11:55 AM
#84
Corona
The ones i'm thinking of are like this example:
https://www.amazon.com/Carlon-BH118R...cal+box+1+gang
The two corner tabs tighten up with a screwdriver to hold it in and the flanges on top and bottom hold it more or less flush to the wall. They make them in various types and depths...
06-05-2018, 01:33 PM
#85
Fleming Island
Those Carlon boxes are made in several versions, one is called shallow and is the smallest one. It was still wouldn't fit in between the walls. The depth of the box was actually OK but I couldn't maneuver it in between the skins due to the tabs.
Al
06-05-2018, 11:47 PM
#86
Corona
Shore Power GFCI Tripping
Sometimes a little trimming of the opening is necessary, even in drywall.
When I have to slice into the aluminum bits, I make sure DW is NOT watching[emoji3]
06-06-2018, 01:26 AM
#87
1979 23' Safari
Wayland
, New York
I used these.
https://www.homedepot.com/p/Carlon-1...-UPC/100404058
Riveted to the skin at the tabs. Cut the box hole carefully to just fit the box through. Shallow enough to fit in the walls. Only deep enough for regular outlets so gfci function where needed or desired was accomplished at the breaker.
