06-03-2018, 08:55 PM
2003 30' Classic
Sandersville
, Mississippi
Battery exploded
On my 2003 Classic I've always left it pugged in inside my shop. Last fall I had one battery explode. Am I doing the right thing leaving it plugged up?
06-03-2018, 10:07 PM
Alamo Heights
With an '03 w/ the original converter, probably not. You'd be able to get away with it for a while if you check the water levels regularly, etc, but the older converters aren't great at "float" maintenance of batteries, it's not exactly what they were designed for.
Batteries also are not eternal... how old was the battery that popped? Were the batteries a matched pair? (different battery condition can cause uneven charging of one battery in a pair, for example.)
My trailer has a "Zamp" power inlet next to the batteries, so I set up a connector for a dedicated smart battery maintainer and I leave THAT plugged in, not the whole trailer. So far, so good.
— David
06-04-2018, 05:08 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard 👍
OEM 74 Series Parallax Converter? 👎.....NOPE 😳
First major 'upgrade' we did was getting rid of that battery burner...😂
06-04-2018, 08:41 PM
2016 30' International
redondo beach
No.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
06-04-2018, 09:35 PM
1974 Argosy 26
Morrill
, Nebraska
My coach is plugged in 24/7/365 except when in tow. Never had a battery problem.
With the right converter it should not be a problem.
06-06-2018, 07:41 PM
2008 19' International
Lincoln
, Nebraska
Many people have swapped their single stage Parallax charger/converter to the PD 4655 three stage charger, which will charge your battery to a certain (appropriate) level and then float (trickle charge) to avoid overcharging. Talk to Randy at Best Converter. There are several threads on doing this yourself.
Happy trails,
Mike
Mike (W9LG) and Jennifer
2008 International 19' Ocean Breeze, Equal-i-zer WDH
2015 Ford F150 4x4 Lariat SuperCrew EcoBoost, 3.55, Max Tow
06-06-2018, 08:22 PM
Lincoln
, Nebraska
And BTW, welcome to the forum.
Happy trails,
Mike
06-06-2018, 10:25 PM
2007 27' International CCD FB
San Diego
As one that has solar and parks in the open, I never bother plugging her in. She's always topped off and ready to go. And the solar chargers are almost all full featureed with great battery maintenance strategies.
I know this doesn't help you for your storage situation. Still need to check batts annually to make sure they have sufficient water to help them last longer.
