hi guys
have a 2013 23FB INTER
im second owner...AS was layed up for years and lived in..all stripped.out and fresh as a daisey nowdays after 4 months of fun....
when i turn on pump in dunny....its takes a while to kick in....?
and when it does its kinda sluggish ?
if i turn on dunny lights while pump is on...the lights flicker and sometimes cut out and the pump too!???
then i check the fuse panel near floor under fridge and see a red fuse light ..i touch the fuse the pump comes back on and sometimes fuse light goes out???
so i have a pump/light gremlin???
im putting money on a couple of ideas
1. pump in on the same
12v feed and the light switch in dunny as the pump water tanks panel in directly above light switch...so maybe too small a
12v dual core cable to handle the feed to both?
2. the pump is stuffed and is causing resistance in the line so cuts out and affects andything else on that
12v feed?
please advise as the AS is working well otherwise
