New electrical system tips
So I've currently got the inside skin removed from my 1978 Argosy. Just about to start electrical and insulation, but I wanted to see if anyone had some tips as to what power source to use for which electrical components in the trailer. I plan to use a mobile 120w solar panel with this system, and two type 27 deep cycle batteries, and a 50 amp (or more) panel with a 50 amp connection cord. I'm not going to install a microwave, but i'm tempted to use a removable electrical range if the weather isn't conducive to cooking outside. So far I've got all of my electrical appliances that i'll need inside except for my lighting. I'd like to find some LED lights with warm light, with an aluminum housing finish, that can also dim. So far all of these that I've found run off of AC, but I'm thinking that if i'm not hooked up to a stable power grid at a campground or at home, that i'll want the lights to run on DC. Anyways, I'm having an electrician do the work, I just want to make sure that I'm getting the right gear for him to hook up before I turn him loose in there. Any tips would be greatly appreciated!
