Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-10-2019, 06:44 PM   #1
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
LED switch position indicator lights.
I posted this in my BLOG but probably get my visibility in its on thread.
http://www.airforums.com/forums/blog...or-led-s-3054/
Finally got to this little project/MOD. The addition of LED indicator light above the electric and propane switch that illustrates when the switch is in the on position. This makes knowing if the water heater is on or off as simple as a glance.
I had a friend who did this to his trailer give me the pair of Linrose LED’s that I used for this project. Model number B4302H5 12V Here’s a link
http://linrose.com/leds/
This project was a little more involved than some I have done, not hard, just tedious.(small parts)
Start by removing the switch cover by slipping a small flat head screwdriver behind the cover a prying it off. You will then need to carefully mark the locations for the 2 LED lights above the switches on the switch cover. Once you have the locations marked you will need to carefully drill two pilot holes in those locations and then enlarger the holes to the required 17/64” for the LED bezel.
I soildered a piece 24ga wire to each LED lead and isolated the leads with heat-shrink.
The rest of the project involved connecting the (-) Neg leads of each LED to the negative wire on the failure light and the (+) Pos lead from each LED to the switched side of its correlating switch. (LED will illuminate when switch is on and turn off with the switch)
When all hooked up, confirm everything works as it should and reinstall the switch in the wall. Be careful to tuck all the wires back in place neatly and resecure the switch cover.
Wow this one was hard to explain. Hope the details are at least somewhat clear. See the photos for more detail.
ID:	349032   Click image for larger version
ID:	349034   Click image for larger version
ID:	349036   Click image for larger version
ID:	349038   Click image for larger version
ID:	349040   Click image for larger version
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 10-20-2020, 02:43 PM   #2
Brainodo's Avatar
2020 27' Flying Cloud
Thanks for posting this! I used it for adding leds to the switches in our Flying Cloud next to the door.
Name:	Led lights for step and outside lamp.jpg
Brainodo is offline   Reply With Quote
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 10:05 AM
WFCO LED Fuse Fail Indicator Boxite Batteries, Univolts, Converters & Inverters 0 08-22-2015 04:18 PM
LED tank indicator panel for bathroom rippie Lights - Interior & Exterior 3 01-21-2014 03:32 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
