Old 07-05-2017, 01:14 PM   #1
2006 25' Safari
Denville , New Jersey
converter /battery
which type of converter/battery charger is installed in 2006 safari special edition.
palski is offline   Reply With Quote
Old 07-05-2017, 01:20 PM   #2
1955 22' Safari
Laredo , Texas
Boiler:-)
Most likely a single stage Parallax.
55AS is offline   Reply With Quote
Old 07-05-2017, 01:56 PM   #3
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
According to the owners manual:
https://www.airstream.com/wp-content...safari2006.pdf
on page G-3 it's a MagneTech 7300 (Paralax came along a bit after the manual came out).
The Paralax manual is at:
http://d163axztg8am2h.cloudfront.net...bea329205a.pdf
The 7300's turned into the 8300's via a key click in the marketing department. The 7345 converter turned into an 8345 with the same key click. Before or after the key click, it's a basic two step (constant current followed by fixed voltage) charge cycle device. It may or may not have a float step after that. If it does the utility of that step (as implemented) is *highly* suspect.
Simple answer - replace it.
uncle_bob is online now   Reply With Quote
Battery converter not charging battery airstreamz Electrical - Systems, Generators, Batteries & Solar 7 10-21-2023 03:10 PM
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
