Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 12-05-2020, 02:24 PM   #1
1993 21' Sovereign
Bishop , CA
breaker problems continue!
OK I started this problem by connecting a generator that pit too many volts into basecamp system . It surged to 160 volts maybe more.
The converter burned out. I talked with a tech at WFCO and bought a new one.
I installed it and the converter does work! so does the AC. All 12 volt systems work off battery or converter.
But the 20 and 15 amp circuit breakers will not stay on. I reset them and they trip off.
the 20 amp runs the furnace and hot water
the 15 amp runs fridge and all the outlets.
I read an old post that said to turn everything off, incl 12v system.disconnect furnace, hot water everything. plug in to shore power 110, then turn on 30 amp main
no luck
any ideas out there?
thanks
geo
geoloz is offline   Reply With Quote
Upgrade kit Fantastic Fan and continue to use wall thermostat A W Warn Roof Vents, Skylights & Fans 2 07-05-2019 04:37 PM
edit to continue an ad mgann Forum Admin, News and Member Account Info 4 11-06-2010 04:20 AM
And the leaks continue.... kidsgone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 18 07-18-2010 07:43 PM
Leaks continue... kidsgone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 03-22-2010 11:10 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
