RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-02-2020, 01:34 PM   #1
1983 31' Excella
Big Bear City , CA
New 7 pin wiring gauge question
So I'm just about to run my new 7 pin system wiring on my 1983 31' excella resto. I plan on running a loom from the plug to a junction box and run all my wiring from there... The only problem I'm having is that I've read that I should be running 10ga wiring to my brakes but I cant find any loom with 10ga for the brakes (most run 12ga for blue). Any thoughts would be great! thanks!
mjameswilson is offline   Reply With Quote
Old 12-02-2020, 02:18 PM   #2
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Just buy a piece of 10ga from Lowes/HD at the correct length and pull it through the loom. You can either leave the old one as an extra, or pull it out to avoid confusion in the future.
kidjedi is offline   Reply With Quote
Old 12-02-2020, 02:22 PM   #3
kidjedi's Avatar
1972 25' Tradewind
1975 24' Argosy 24
Denver , Colorado
If you're buying a "bundle" (a loom with the seven appropriate wires), you might also consider upgrading the 12v "charge from alternator" wire so you're getting more juice to the house batteries while you're traveling. You should also increase the wire size from the alternator to the trailer plug as well as the wire in the "umbilical" from tow vehicle to trailer. None of these are critical, but your batteries will charge a little faster while you're in transit.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
Old 12-02-2020, 03:21 PM   #4
batman's Avatar
1964 22' Safari
modesto , California
Hello Big Bear,
The Umbilical Cable I use has 1/8, 2/10, 4/12 gauge. Example: https://www.anythingtruck.com/product/595-3329.html
Mine is black, I got it from a friends shop. I am not sure you need 10ga but they are out there.
Since you are rewiring. you might also consider a HD round pin 7-wire plug and socket, https://www.anythingtruck.com/product/595-3329.html IMO, A few advantages over the flat blade style plug and socket. Sturdier, the -NEG ground makes connection first, more solid connections, seems to be more corrosion resistant, perhaps a little more security - not everyone has one.
-Dennis
batman is offline   Reply With Quote
Old 12-03-2020, 07:13 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
....The only 10g wire in most quality replacement cords is the ground & chg-power.
"Black: 10AWG 12(+)/Auxiliary; White: 10AWG Ground(-)"
POI..never had a problem with the 12g in "Cloudsplitter"
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Change is the new normal, if nothing changes, nothing is normal, everything changes, everything is normal.”
RLC
Tahawus
Old 12-04-2020, 09:21 AM   #6
1983 31' Excella
Big Bear City , CA
Ah yes this is a great solution. Thanks!
Old 12-05-2020, 08:43 AM   #7
batman's Avatar
1964 22' Safari
mjameswilson, This is the HD round 7-pin connector I was trying to show you in my last post.
https://www.anythingtruck.com/product/810-593057.html
IMO It is much better than the flat blade style.
Good luck,
-Dennis
Old 12-05-2020, 09:34 AM   #8
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
I used the 7pin round on my 72 Sovereign. It makes a better connection on my trailer plug plus not too many people have these so theft of my trailer is reduced so far. Good luck.
cole3444 is offline   Reply With Quote
7 pin to 4 pin - Jeep wrangler 42570 Our Community 6 09-08-2010 10:44 PM
9 pin to 7 pin conversion ck21084 Electrical - Systems, Generators, Batteries & Solar 4 06-10-2010 03:58 PM
6-pin connector to AS 7-pin eugnicfrlie Towing, Tow Vehicles & Hitches 6 04-15-2009 11:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 02:34 PM
