Old 09-09-2010, 08:11 PM   #61
x
XXXX , XXXX
Musicmaster I priced crossmembers and outriggers from factory at about $750 and had the main frame rails made by a friend for $150. Probably would have cost $400 for main rails by steel shop. A local welder quoted me $1000 to do all welding but got another friend to do it for free.
wasagachris is offline   Reply With Quote
Old 09-09-2010, 11:35 PM   #62
qc1500's Avatar
rozenburg , netherlands
I live in Europe so can tell you the costs in Euro's. Material was 500 euro but without the outriggers, i ordered them in the usa, about 250 dollar. I had to pay 3000euro's including the welding and material so the welding about 2500 euro. The welder also removed and placed the axles.
1974 31ft sovereign international
1976 SMV 520
towed by 2005 Dodge ram SRT-10
qc1500 is offline   Reply With Quote
Old 09-22-2010, 01:51 AM   #63
qc1500's Avatar
the new frame is being painted
1976 SMV 520
Old 09-22-2010, 04:31 AM   #64
x
XXXX , XXXX
Hi QC1500 Excellent looking frame. It is eerily similiar looking to mine. I see you made all the crossmembers the same height. How do you intend to reinforce the seams where the floor sheets meet?
Old 09-22-2010, 06:55 AM   #65
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by wasagachris View Post
...I see you made all the crossmembers the same height. How do you intend to reinforce the seams where the floor sheets meet?
Must have been a design change between the '73 and the '74 model. The '74 frame (like my '78 frame) is dead flat all the way down from front to back. The seam joints were simply butted together over the appropriate cross member and elevator bolted into place over the cross member with no plywood doubling under the joints.
The '78 has a 1/2" plywood floor and a super light frame similar to qc1500's original.
Congrats to qc1500 and any others replacing their too light frame with a more robust model.
"...do it right the first time..."
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-22-2010, 08:02 AM   #66
qc1500's Avatar
I kept it flat all the way. There is no problem to bolt the floor into place.
I changed a few other small things but most things are the same, only stronger.
Today i build in the citywater tank, and fits perfectly. Only the waterline was broken because of frost i think, and that size isn't available in Europe so i fixed it with a hose.
1976 SMV 520
Old 09-22-2010, 01:11 PM   #67
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
That's a spectacular frame. I am jealous!
TX-16
Dave Park is offline   Reply With Quote
Old 10-24-2010, 12:17 PM   #68
qc1500's Avatar
a few more days to go and then the frame and shell will be reunited
1976 SMV 520
Old 11-04-2010, 11:11 AM   #69
qc1500's Avatar
Shell is back on the frame
1976 SMV 520
Old 11-04-2010, 11:35 AM   #70
dznf0g's Avatar
Oswego , Illinois
qc,
Tell us about the vents in the underbelly. I have been considering this, perhaps with a couple of 12V 4" computer muffin fans for forced air ventillation. How many did you install?
Old 11-04-2010, 11:54 AM   #71
qc1500's Avatar
I noticed that any water that could come in the underbelly, had no way out. So the frame had to rot...
First i will make sure that the change of water will be reduced to the minimum and hopefully none.
But at this way it can ventilate. The louvers are pointed backwards.
I placed one between every 2 crossmembers. I will place smaller ones at the left en right side of the bellypan. So i hope water will have no change to do damage again.
The vents have, i don't know who to call it in English but, stuff to keep insects away
1976 SMV 520
Old 11-04-2010, 12:29 PM   #72
dznf0g's Avatar
Oswego , Illinois
Thanks, that's clear.
Old 11-07-2010, 11:14 AM   #73
qc1500's Avatar
you're welcome.
1976 SMV 520
Old 11-17-2010, 09:50 AM   #74
qc1500's Avatar
Floor is back in.
1976 SMV 520
Old 01-09-2011, 09:18 AM   #75
qc1500's Avatar
another small step
1976 SMV 520
Old 01-17-2011, 02:47 PM   #76
qc1500's Avatar
It is getting together
1976 SMV 520
Old 01-17-2011, 03:55 PM   #77
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
Screens?
cclarkego is offline   Reply With Quote
Old 01-17-2011, 09:09 PM   #78
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Thumbs up Nice
Looking great QC.
Lance
Lance M is offline   Reply With Quote
Old 01-21-2011, 10:09 AM   #79
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Aluminum Frame
Originally Posted by qc1500 View Post
The new frame is coming together, only a few more days of welding
Nice work.
But I wonder why no one seems to make the frames with ALUMINUM?
The cost would not be that much more and the ability to carry more, or pull less weight, would be an advantage.
Shinning the underside would be a challenge though.
Dave
Old 01-22-2011, 12:24 AM   #80
Trex's Avatar
1981 20' International
Shasta Lake City , California
I don't what to look under my 72/31'
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: https://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
1974, 31', europe, sovereign
Rotten frame photos attached arrgghh 2vets Repairing/Replacing Floor &/or Frame 56 05-12-2011 07:37 PM
Rotten Wood adonh Interior Restoration Forum 7 11-21-2009 10:58 PM
What to do? Rotten floor cbl3030 Repairing/Replacing Floor &/or Frame 13 08-24-2006 12:25 PM
Rotten floor BurnBound Repairing/Replacing Floor &/or Frame 16 02-05-2006 08:03 PM
