Old 07-04-2003, 05:35 PM   #1
Don in E Texas's Avatar
Carpet Squares
Today I removed all the old carpet, pad, staples, etc and have the "wood" all cleaned up and ready for new carpet.
What I've decided to install is 18" square Commercial Grade carpet squares. Just lay down some double sided carpet tape and place tiles. The seam is not visable (some patterns the seam is visable - depends on what style you may want). To remove a tile (to clean, or replace) just grab it with pliers and pull.
Cost is about $1.00 per ft.
Just another idea for the group.
don
Don in E Texas
Don in E Texas is offline   Reply With Quote
Old 07-04-2003, 07:43 PM   #2
I'm using commercial rubber backed carpet runner-36"wide-..cut it to fit, droped it in. When it is dirty I remove it to outside and wash it with the hose....let it dry over fence and back in it goes....doesn't shift when towing....I painted the wood floor with 2 coats of porch enamel and a coat of sealer, so it is water resistant/proof....took 40' rollX36" wide because I have stripped out the interior of my old '77 and made it more "spartin"....couldn't stand the fru-fru dust dirt cloth colors and mold!.....geof
geof is offline   Reply With Quote
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
Putting in new carpet wardster All Argosy Trailers 1 02-03-2004 12:02 PM
Carpet Replacement with wood Roger and Nancy Floor Finishes 32 12-07-2003 11:06 AM
Pergo or ? instead of carpet Kistler Floor Finishes 38 04-20-2003 08:19 PM
Carpet Cleaning Advice JaceBeck Upholstery, Blinds, Walls & Interior Finishes 4 03-26-2003 10:25 AM
