Originally Posted by Kawabonga
Does anyone have any suggestions with regard to axles? I'm considering upgrading to 5200lb axles with 6 bolt rims. Does this make sense or would these be too stiff? What about tires, any suggestions there?
It would be ill advised to upsize your axle capacity. You are correct that they would be too stiff. Colin Hyde is an excellent source of axles. He can help you size appropriately, and can order in increments of weight capacity that are not available to standard Dexter axle dealers. He can also help you decide if you want to change the degree of the torsion axle which can give you a little higher stance than original.
It looks like someone put an incredible amount of time and money in your Airstream so far. Good luck!
