2003 International CCD 22’
I’m looking at buying a friends 2003 Intl CCD 22’ trailer. Back in 2012 he had the following done: (Per repair invoice). Repair cracks in main right side chassis frame- straighten and support frame outriggers @right side. Grind, weld and plate cracks in frame- notch outriggers for bracing- fabricate and weld additional steel frame material to support main frame, front to back. Add gussets/ plating to outriggers to straighten and reinforce- drill and bolt cross frame braces- paint frame as needed. To those of you familiar with this frame problem with this model, an opinion of the work done would be appreciated. He also had a new floor installed at that time that was damaged. Total repairs were approximately $12K…I will be having it inspected before purchasing, but, again, just looking for some input/ opinions/ recommendations from this very knowledgeable community…Thanks in advance…
