Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 02-14-2021, 10:43 AM   #1
2015 27' FB International
Chico , California
TV antenna/ cable hookup
Would anyone explain what setting to set your TV after connecting to cable at RV parks? Also, how to set up the antenna to obtain local channels? We are currently using a Dish Tailgaters without problems. Would be nice to do get local channels/news where we travel to.
elsewhere is offline   Reply With Quote
Old 02-14-2021, 11:04 AM   #2
Mollysdad's Avatar
My TV's are Samsung. The menu might vary a bit between brands, but the concept is the same. On the remote select "menu". That brings up a list. Scroll down to Picture (or Channel) , and you have a choice of "air" or"cable". Since you want to use your tailgater, not cable, select "Air". Then do a channel search. Then make sure the button on the wall plate is depressed, and it should illuminate. You need that anytime you select air. It's twofold, one, it selects the roof antenna, amplifies it AND it switches between the cable and antenna, so if it's out, you are looking at the cable coax (which you're not using.) You see there's only one coax input to the TV and that's why.
Conversely, if you're connected to the park cable, switch the booster off, go to menu, select cable and do another channel search. Sadly there's only one search so you need to repeat it when changing from air to cable.
I don't know how the satellite gets to your TV, perhaps the HDMI? So in the main menu you should be able to switch between the HDMI and the coax (roof antenna).
ID:	388703   Click image for larger version
Mollysdad is offline   Reply With Quote
Old 02-14-2021, 11:36 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You can get local channels with your dish tailgater combo by contacting dish support and changing your location. Use the address of the park you are camped in and the local channels will be available in a few minutes.
Richard
Old 02-14-2021, 11:45 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Assuming you have a local channel subscription with Dish. If not there will be a charge to add locals.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 02-14-2021, 12:04 PM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
My package must include local channels, did not realize that it was not standard.
Richard
Old 02-15-2021, 11:12 AM   #6
1988 32' Excella
Robbinsville , New Jersey
Some cable systems require a cable box which requires ANALOG channel 3 or 4 be used on your TV.
Wazbro is offline   Reply With Quote
Old 02-15-2021, 12:54 PM   #7
2017 20' Flying Cloud
austin , Texas
Another alternative to azflycaster's suggestion of calling DISH support (which I used to do) is to download the MyDish app. You can pay your bill, change to local channels as you travel about, add channels, remove channels, etc. It's under Services.
ejami5 is offline   Reply With Quote
Old 12-17-2023, 08:35 AM   #8
2023 25' Globetrotter
Kalispell , MT
Turn off green light
First time.
We do not want the ability to turn on the TV
But the little green light is annoying and I can't find any way to turn it off
MrsTina is offline   Reply With Quote
Old 12-17-2023, 08:50 AM   #9
aftermath's Avatar
Spokane , Washington
Just toggle the little black button next to the coax connector in Mollysdad's picture.
aftermath is offline   Reply With Quote
2011 International EXT cable hookup not working alozier Audio, Video & TV 6 10-20-2011 03:42 PM
Where is the cable hookup????? frankandsue Land Yacht/Legacy Motorhomes 5 10-03-2009 03:14 PM
Understanding Tv cable hookup. Wingeezer Audio, Video & TV 8 11-13-2008 06:08 PM
Cable/sat hookup/leveling jacks Ga Pockets 1984-1988 Limited 10 01-14-2005 02:08 PM
Cable/Phone HookUp Cat Community Polls 9 10-24-2004 10:23 AM
