Yes, sort of. There is an antenna booster switch that has to be turned off to let that cable input work. There should be an outlet cover with a small push switch somewhere in the AS with an LED and a push button switch. If the LED is off, you are set to cable input. At least that’s how it works on my ‘07 International.
