Airstream Diesel Pusher Motorhome 396XL 2003 Land Yacht for sale
Www.airstreamclassifieds.com Georgia
Top-of-the-line coach with the famous Airstream quality throughout on Freightliner Chassi with Diesel CAT 350 engine also known as the commercial million mile motor. Barely broken in 160k miles lovingly used, and maintained, started and driven every month, rather than just sitting. This beautiful coach has only two owners. The six speed Allison Transmission causes this Coach to drive with only a touch of the accelerator, whether towing or not. Leather driver seating with power adjustments and massage. Hydraulic levelers make set up easy. Everything in excellent condition, with dozens of upgrades throughout. The air ride suspension, cold dash 2 air conditioning units and excellent heat makes for a comfortable trip for all aboard. All new LED white lights inside and out for brighter headlights, fog lights and interior lighting. 2 slide outs for kitchen area and full wardrobe to enlarge kitchen and bedroom. Neat and very clean interior with new recliner and newly reupholstered large Sofa in front which makes into full size sofabed. Easy Power cord advance/retract for power to plug into 30 or 50 electric amp, or flip on your 8kw Cummins Onan generator with 2 push button start/stops, as needed. Walk around Queen size bed in the rear with under bed storage & Large cedar wardrobe and extra closets with loads of storage. Split bathroom with large glass shower enclosure and a lavatory private room. Large sink and medicine cabinets. Corian countertops in kitchen, dining table w/ Corian leaf & matching chairs, refrigerator with freezer, pantry slide out, updated lifetime high end Vinyl flooring. Brand new upgraded Microwave/Convection oven. Dual ducted gas and electric furnaces, both roof A/C’s just serviced and produce cold air with upgraded low volt quiet starters Micro Air EasyStart on 15,000 BTU Air Conditioners with new A/C shrouds. 100 w Solar panel for extra battery charging. Carbon Monoxide detector and propane alarm. All solid light maple wood cabinets & 6 panel solid doors. New AM/FM radio; CD, CD/DVD/Surround sound. 2 flat screen TVs with outside plug for extra TV, ROKU and Samsung Apps & WiFi components, Satellite and all cable wired, WiFi Ranger antennae and brand new Winegard RVW-395 Sensar DTV/HD TV antennae. Inverter converter and additional new 2000 kw charger inverter for your computer protection. Full fiberglass roof cover, aluminum wheels, all Michelin radial tires with not more than 10,000 miles. Full Awnings, Backup monitor, Air Horn, Splendid Washer/dryer, thermal windows with upgrades and double blinds, 3 skylights w/ shades, 2 vents with Fantastic fans & rain sensors, new water pumps, new alternator, new batteries. Tire minder sensors with App for monitoring. Chrome heated mirrors, full basement for maximum storage. No smokers/No pets. Loaded w/ extras. Yearly Service Done by Freightliner and Main Service Center in Gaffney SC. This is one of the best and most reliable motor homes available.
Options and Standard Features
Basic Information
* Year: 2003
* Make: Airstream Motorhome
* Model: Landyacht 396XL
* Trim: 39 ft Diesel Pusher
* Type: Motorhome
* Sleeping Capacity: 4
* Length (Feet): 39
* Construction Body Material: Freightliner Chassi
* Sidewall Construction: Aluminum
Suspension / Braking / Wheels
* Tire Brand: Michelin
* Front Tire (Full Spec): Radial
* Rear Tire (Full Spec): Michelin LT225/75 R16
* Rear Tire Aspect Ratio: 75
* Rear Tire Width: 225
* Rear Brake Type: Electric Drum
Drivetrain
* Number Of Axles: 3
Safety
* Smoke Detector
* Carbon Monoxide Detector
* Propane Alarm
* Rear Video Backup Camera
* Emergency Exits: 1
Exterior
* Exterior Flood Lights
* Exterior electric hookup
* Retractable Roof Antenna
Interior
* Interior Color: CREAM/SOLID MAPLE
* Living Area Location: Center
Comfort
* Heaters: 2
* Number Of Sofas: 1
* Number Of Convertible / Sofa Beds: 1
* Air Conditioning 2 Type: Automatic
* Reclining Sofa and chair
* Sofa Material: New cloth
* Heater Type: Automatic
Convenience
* Power Vent Fan
* Sky Lights
* Roof Vents
* Leveling Jack Type: Front Manual / Rear Manual
Entertainment
* DVD Player
* Television
* Radio
* TV Antenna wired
* Cable wired
* Surround Sound
* Satellite wired
* Number Of Radios: 1
* Number Of Flat Screen Televisions: 2
* Speaker Location(s): Interior front and back
* Television Brand Name: Samsung
Slide-Outs & Awnings
* Slide Outs: 2
* Awnings All windows
* Awning Large Canopy
Towing
* Hitch Lights
Utility Hookups
* Number Of Propane Tanks: 1
* Water Heater Pump Power Mode: Electrical / Propane
* Water Heater Tank Capacity (g): 6 (l): 22.7
* Total Propane Tank Capacity (lbs): 80
* Propane Tank Gauge
Holding Tanks
* Water Capacity (Gallons): 51-60
* Fresh Water Holding Tank Gauge
* Gray Water Holding Tank Gauge
* Black Water Holding Tank Gauge
* Total Black Water Tank Capacity (gal): 39
* Total Fresh Water Tank Capacity (gal): 54
* Total Gray Water Tank Capacity (gal): 37
Electrical / Generator
* Exterior Plugs
* Ground Fault Plugs
* Battery
* Air Conditioning Prewiring
* Heat Prewiring
* Battery Converter Amps: 55
* Battery Power Converter/Inverters
