Old 06-21-2021, 10:19 AM   #1
Reformed Engineer
EngiDent's Avatar
1967 26' Overlander
2000 35' Land Yacht XL w/2 slides
Spartanburg , South Carolina
Tire pressure, 2000 Land Yacht 355XL
Hi
2000 Land Yacht 355XL, F53 chassis
Wasn't sure which forum to post this in because it has a flat front and is an XL, but is also a Land Yacht.
Owner's manual says 65psi for tires, but everything I've read elsewhere suggests people are running in the 80's. Why is the manual suggesting such low pressure?
Any suggestions for reaching rear valve stems, or a particular extender kit that might work?
Dave
EngiDent is offline   Reply With Quote
Old 06-21-2021, 02:08 PM   #2
Berkel-Enschot , Noord-Brabant
To get a better picture this " pigheaded Dutch selfdeclared tyrepressure-specialist " would like from tires next.
1 maxload or loadindex
2 kind of tire to determine referencepressure ( behind AT ) , probably 65 psi D-load .
3 speedcode or maxspeed of tires.
Configuration of motorhome.
Think 2 axles ,rear dualload.
GAWR'S and GVWR, and if you ever weighed fully loaded those real axle( - end) loads
Then I will calculate my advice, and show how I do it, so you mayby understand better the to your idea low pressure.
Even extenders exist so you can fill inner and outer tire at the same time, and pressure of both will be exactly the same.
jadatis is offline   Reply With Quote
355XL TV antenna wiring problem EngiDent Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 06-21-2021 10:16 AM
TV Tire Pressure & RV Tire Pressure Q's starpicker Towing, Tow Vehicles & Hitches 37 05-26-2021 09:02 AM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Land Yacht :: 2000 Airstream Land Yacht jrkeef Airstream Registry Discussions 0 02-18-2013 06:01 PM
Tire size for 2000 diesel 35' land yacht xc? dhshipley Tires 0 07-24-2009 12:21 PM
