Old 02-18-2018, 09:37 AM   #1
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Fridge vent fans
Hey all
To bob miller.
Bob, you mentioned in a previous post about installing a fan and baffle system when installing a new fridge. I'm going to get a new 3 way fridge for our 325. Could you elaborate on the fans and baffle setup you suggest. Moving hot air out of the back area is a good idea. I thought of putting a 10 inch fan on the access door. What say you. Seems like a better idea, to move the hot air up and out. Thanks. DJ
davejay is offline   Reply With Quote
Old 02-18-2018, 05:23 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
2 4" fans will fit perfectly into the chute above the refrigerator, don't forget to install a baffle as Airstream didn't, there is to much free dead air space between the coils on the back and the wall. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 02-18-2018, 08:29 PM   #3
Fridge fans
thanks Bob,
I though that's what you meant. 4 inch computer fans low amp draw super quiet, and they move a lot of air. Basically , block off the big square hole, so only the fans draw the air . I wonder if new RVS have this setup. One would think so... I'm going to put some filter material on the assess door too, to keep bugs and dirt from getting behind the fridge.
Thanks Bob. DJ
Old 02-19-2018, 07:03 AM   #4
Fridge vent fans
hello all,
To Bob Miller,
Sorry to bug you, these fans, 12 volt, 120 volt, do they make one that is both voltages? You wouldn't by chance have a model number?
Here's a weird question . When your on 110 , does your 12 volt stuff still work? Or was the unit designed to switch between voltages. My 325 has some awful thick wiring for stuff like overhead lights
Thanks. DJ
New Fridge, Old Fridge Vent TMT Refrigerators 0 10-17-2015 07:23 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Best place for Fridge Fans ventport General Repair Forum 8 08-09-2012 06:25 AM
fans or no fans goransons Refrigerators 8 12-31-2007 12:21 PM
