Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 11-19-2021, 06:03 AM   #1
1989 34.5' Airstream 345
Kingsland , Texas
Fresh water tank and drain
Winter is coming, and Id like to make sure the fresh water is all drained out. Where do I find the tank and the drain for this? There is a large tank near the back that has a drain, but it looks more like a fuel tank to me.
89 345LE
thanks,
Aaron
Airdelroy is offline   Reply With Quote
Old 11-19-2021, 07:37 AM   #2
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
It’s a small white valve between the wheels, just open it up and let it trickle.
- Stewart
s1000pre is offline   Reply With Quote
Old 11-19-2021, 07:39 AM   #3
s1000pre's Avatar
I just realized you have a 1989. The white valve between the wheels is on newer models. I’m guessing yours is the same or very similar. Fresh tank is typically located near or over the axles. Check on either side for the valve.
- Stewart
How to keep fresh water tank fresh and tasting good Driftin Di Fresh Water Systems 26 04-24-2021 05:23 AM
Snow Socks and how to drain fresh water tank Jasper14 Sprinter and B-van Forum 3 10-17-2019 04:41 AM
Fresh water tank repair and rebuild black and grey water valves Sierra Skier LP Gas, Piping, Tanks & Regulators 0 07-25-2018 10:55 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
