Old 10-09-2015, 10:28 PM   #1
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
Cabin side panel removal
This is a how-to for removing the cabin side trim panels. I did it by trial and error, mostly error, since I could not find a description of the procedure anywhere. It is much simpler than it looks, and most of what you think you will have to do is unnecessary.
1. Remove the three plastic woodgrain panels. The two outer ones are glued on, and must be levered up gently with a paint scraper or similar. The central panel is glued to a black plastic panel that is held by 4 tabs, approximately shown in the picture. Gently lever the tabs out. You will see two horizontal lines of rivets revealed, holding a chrome-and-black plastic frame.
2. There is also a vertical line of rivets at the rear edge of the panel, covered by a white plastic strip that pops out from the bottom to reveal the rivets.
3. There is a line of carpet staples at the bottom that will need to be pulled out.
4. Drill out the top line of six panel rivets, but don't drill out the bottom line too, as I did. You can leave the plastic frame in place.
Note: On mine there was a single seventh rivet hidden behind the top center of the plastic frame (shown in blue on the picture). You should be able to feel it by sliding your scraper blade behind the plastic frame, and then drill through the plastic to drill out the rivet.
5. With the rivets drilled out, slightly pull out the panel at the bottom and lift the whole thing up. It's done. I did not need to completely remove mine, and I think that there are one or two rivets at the front that I did not attempt to access. It might just be another slide fit though, if you want to remove the whole panel completely.
6. When I reassembled mine, I drilled out the rivet holes for the top line and the rear vertical line of rivets with a 0.149" drill bit, then screwed in #8x3/4" stainless steel tapping screws. I did not replace the hidden rivet, which must just have been for location during factory assembly. The plastic panels and strip all still fitted, and now I can take it apart in future much more easily. I velcroed the outer small woodgrain panels on instead of gluing them, but the center panel pops back in.
Note: be careful not to unplug the complicated power seat switch connector, if you have this. Make sure that your power seat controls work before re-securing the panel. I also took the opportunity to fill the armrest portion with more insulation.
A final note: this job would be very difficult with the seats in place. There are four small nuts securing the seats to their plinth base, and it takes just a few minutes to remove them, and then the seats can be laid back gently to lie on their backs in the lower area behind. No need to unplug them, as the power cord is very long.
Good luck!
1989 345LE
Punch is offline   Reply With Quote
Old 10-10-2015, 06:37 AM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Thanks for posting this, Bob!
The cab area is my next battleground and I never removed this type of side panel.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 10-10-2015, 09:33 AM   #3
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Thanks PUNCH. Great detail. I'm definitely saving this one.
streamquest is offline   Reply With Quote
Old 10-10-2015, 05:40 PM   #4
I could be mistaken but when I dismantled the 86 345 I too am thinking there were a couple of hidden rivets that are difficult to get too. I think your advice is the best, unless you absolutely have to completely remove the panel leave well enough alone and forget those hidden rivets!
1975 24' Argosy Motor Home
Old 10-11-2015, 10:05 AM   #5
Rivet Loser
Punch's Avatar
Brad, I certainly felt that there was very little holding it in place and one good pull would have removed it, but I didn't want to disturb the wiring, and only went in there to investigate a leak.
On which subject..... I found the rubber drain hose blocked on the passenger side, and that had caused major floor damage, luckily just to OSB, In order to make it easy to check that the drain hose is clear in future, I drilled a 1/4" hole in the plastic panel in the area circled in this picture, on both sides of the cab.
Now I can just run a thin wire down the tube periodically. (If you do this, make sure your thin wire doesn't have a razor sharp edge to cut the hose, use some emery to smooth the end off).
Another point I thought of: Make sure all your old rivets are punched out before attempting to drill and screw into the holes. Those old rivets are stainless, and very hard!
1989 345LE
Old 10-11-2015, 05:54 PM   #6
I could be mistaking the 345 for the work I also had to do on my Argosy in the same area.
Attachment 250174
Adding that hole was a great idea. Airstream made a change from the early Argosy models to what you have in the 345. On the early Argosies the floor ends at the inner wall so everything below the window frame is open to the outside. On the 345 the floor goes all the way out to the outer skin which necessitated the need for the hose. I believe in the later Argosies Airstream ran the floor to the outer wall but didn't add drain holes. Net results are what you experienced with the plugged drain hole. I think Peter will be able to verify what I said about the later Argosy models.
I hate those stainless rivets! They are a real bear to deal with.
Old 04-09-2018, 02:23 PM   #7
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
I am trying to pull my side panel for some antenna work, but I am stuck at the wood grain trim panel. I have pried them almost to breaking, but the end sections will not come free. I think they may have glued them on mine?
I dont want to distort the plastic so I think I may use my sharpened putty knife to snap the screws (or rivits) behind the panel.
WayneG is offline   Reply With Quote
Old 04-10-2018, 04:48 AM   #8
Wayne, from what I remember the wood panels are glued in place as you surmise. I was amazed at how hard it was to remove those plastic wall coverings to gain access to the actual wall itself. I'm pretty sure on the 345 the panels were stapled in place as well as riveted. Or more precisely the staples may have come from the carpeting that was glued and stapled to the side panels.
I seem to remember Bob recently pulled his side panels so he might have some good Intel on how to remove them.
I might have a few pictures that I can look for tonight.
Old 04-10-2018, 10:07 AM   #9
WayneG's Avatar
Scotia , New York
I am holding off for more info here. If nothing else I have my mototool standing by. I cut a piece of heavy ziplok bag to go over the blade to avoid scraping the trim parts.
Old 04-11-2018, 08:36 AM   #10
Sorry, I couldn't find any pictures of the panel removal. I thought I had taken some but if I did I can't find them.
Old 04-11-2018, 10:31 AM   #11
WayneG's Avatar
Scotia , New York
No problem, I moved that project to the back burner. If I need a radio I can run the inverter and the surround sound while traveling
The weather is good enough this morning to continue with my electric step installation and some testing on the fluid sensor module.
Old 04-11-2018, 11:50 AM   #12
Now I might have a picture of the wall interior with the panel and interior skin removed showing the cable routing. I'll look tonight......
Old 04-13-2018, 02:28 PM   #13
WayneG's Avatar
Scotia , New York
It got up to 60 today and I was bored so I started cutting.
It all came off, but there were a lot more screws and rivets than in Punch's original photos. I dont know if it is factory work or after the fact engineering.
And I can see my efforts were near to worthless.
I thought there would be a access hole to the rear of the antenna, but no such luck!
It looks like I will have to drill some rivets at the window edge and do some digging.
I tried pulling on the antenna from the outside and a "semi" gentle tug broke the cable. It is in there good
If anyone is interested in more photos of today mess, I put them on my Dashboard remove page at the bottom:
http://theouterlimits.ws/projects/ai...d_Removal.html
Old 04-13-2018, 05:11 PM   #14
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The AM/FM antenna is held in by about a pound of Vulkum.....I have changed 2, one on the 325 and one on the 370. If you need a hand let me know and I'll come over on a Saturday and help you out, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 04-14-2018, 02:13 AM   #15
WayneG's Avatar
Scotia , New York
Thanks, I did manage to get it out.
I drilled the top rivets to give me access. I found the cable was taped to other wires and snaked through some brackets preventing me from pulling it out from the outside. Since the cable broke at the antenna, I was able to pull the rest of the cable from the inside.
I ordered a replacement from Airstream Supply. It aint cheap. $34 for the antenna and then when I went to the online checkout they wanted $32 for UPS ground shipping! I called and got the shipping down to $12, still high. I did not find any other sources of this style:
Old 04-14-2018, 05:04 AM   #16
bobmiller1's Avatar
Wayne, The original antenna is available at Car Essentials in Schenectady for $20.00 , Regards, Bob
Old 04-14-2018, 11:20 AM   #17
Here's some pictures of the 86 345 showing the antenna cable and all the sealant Bob is referring to.
ID:	308677Click image for larger version
ID:	308678Click image for larger version
Old 04-14-2018, 12:15 PM   #18
WayneG's Avatar
Scotia , New York
It looks like your antenna is mounted higher than mine. Mine is below the drivers window, so I did not have too get to deep into rivet removal.
The guy knows you by name, and I guess you cleaned him out on that style off antenna. He has more on order.
Old 04-14-2018, 12:40 PM   #19
This is about the only picture I can come up with showing the outside where the antenna was mounted. I'm surprised they mounted the antenna's in different locations.
Old 04-14-2018, 01:16 PM   #20
WayneG's Avatar
Scotia , New York
It probably depends on if the tall guy or short guy was on shift
Moving around in cabin while in motion ViewRVs Airstream Motorhome Forums 13 07-18-2005 12:13 PM
1963 Overlander converted to a "cabin" 63overlander Interior Restoration Forum 20 03-06-2004 09:41 AM
Cabin Fever BC or Bust Janets Husband Our Community 11 01-17-2004 03:57 PM
Cabin Fever jpurdy Off Topic Forum 11 08-12-2003 01:05 AM
Bad cabin smell from new Solar instalation w9det 2000 - 2004 Safari 7 04-21-2003 10:21 AM
