04-21-2021, 10:45 AM
Bonaventures
2021 Interstate 24GT
Amherst
, New York
Wire Splice on Airstream Connected Router
Looking for some feedback to determine if I have a dealer problem, a manufacturer problem or potentially both.
We recently took delivery of a 2021 Interstate Grand Tour EXT. Well before delivery, I ordered (through the dealer for installation prior to pickup) the Airstream Connected router. At delivery, the router was “installed”. When I went to activate the Airstream Connected service, I discovered that the router was not getting power. Upon inspection, I noticed that the power into the router was not wired to the power terminal block, but rather, through a spliced connection to the 12V-28V DC Jack. To my amazement, the spliced connection was wrapped in black electrical tape without even a wire nut. When I contacted the dealer about the lack of power and the janky wire splice, they indicated that the splicing was done at the factory by Airstream and all they did was connect the router to the antenna cables.
Wondering if anyone else had similar experiences with a factory black tape wire splice or am I getting a line of BS from my dealer?
04-21-2021, 12:56 PM
2019 30' Classic
Canfield
, Ohio
I believe you are getting a line from your dealer. Airstream uses square clear connectors to do splicing. They hold very well and you can see the splice. These are the same connectors used in cabinet lights.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
04-21-2021, 01:11 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
Not sure, I highly doubt Airstream is responsible for that. I will never visit my local service department ever again!!! They were awe full...both times. It was so ridiculous, I will not give them a third attempt.
04-21-2021, 01:42 PM
Magnolia
Did the Dealer give you the key to the powered "Wi-Fi" switch in the DC panel which turns power off and on for the router? If not, I'm guessing they didn't have the key and may have bypassed that switch altogether. If they did, then that router really is plug and play, and powered by that keyed switch, so I'm not sure why they would wire it anywhere else.
04-21-2021, 03:15 PM
Bonaventures
Amherst
, New York
Thank you!!! I tried all the keys that came with the coach and fortunately 1 of them worked on the "powered Wi-Fi switch" on the panel you referred to. That powered up the router. It might've been helpful if the dealer had explained that on the delivery walk-through. Now my only issue is the quality of what looks to be the dealer's shoddy wire splicing, which I'll end up fixing myself. Very much appreciate your cluing me into the keyed switch.
04-21-2021, 08:24 PM
Frisco
I just took delivery this past weekend; April 17th. Your splice job sounds exactly like mine: a dc jack attached to two, spliced wires sobered by black electrical tape. Mine do appear to have crimp connectors under the tape, so it’s a functional connection, I just wished it would have been shrink wrapped.
04-22-2021, 07:47 AM
Magnolia
bassplayrr and tgilbride, what you guys need to do now is confirm that you have the upgraded Magnum MMS1012-L inverter/charger and the Magnum ME-RC-L remote designated for lithium batteries. Many of the new interstates with the lithium battery package came from the factory with the older, non-lithium Magnums. There's a thread below were we've been discussing this. If you don't have the newer versions, it's a trip back to your dealer to get them to change it.
https://www.airforums.com/forums/f24...ml#post2431243
04-22-2021, 11:27 AM
Bonaventures
Amherst
, New York
Thanks. Looks like I have the older (non-lithium) versions of both. Back to the dealer I go ...
04-22-2021, 08:42 PM
Frisco
10-4. Thanks. It’s off getting PPF and ceramic coat now but I’ll be sure and check when I get it back next week.
04-26-2021, 11:03 AM
Frisco
The RV is still at the detail shop, but checking the owners manuals, the remote is not labeled as -L. However, it's listed as revision 2.9. Searching on that a bit, it appears to have the desired functionality for lithium: the 2.9 revision includes LFP presets and compatibility.
04-27-2021, 07:07 AM
Magnolia
Best way to confirm that both your Magnum Remote and Magnum Inverter charger are the correct Lithium versions is through your Magnum Remote control panel. When you get your RV back, select the "Tech" button on the right of the control panel, then rotate the knob to "2 Revisions", then rotate and capture the version numbers of both your Remote and Inverter/Charger. This process is listed in your Magnum ME-RC Remote manual, page 37.
If it shows v2.8 for your remote, and v1.6 for your MMS1012 inverter/charger, you have the non-lithium versions. if it shows v2.9 and anything after v1.6, then you're good.
05-04-2021, 05:44 AM
Wapakoneta
, OH
That is a dealer problem. If they installed the router, they should have known that it needed power. The power cable should be in the same location as the communication wires for the router. They just didn't look hard enough. It shows in the 12V Main Schematic a 14a that is supposed to power the router.
As for the tape wrapped around the connection, I wouldn't say that is a manufacturer problem. I think they were probably just trying to better protect the wire if it wasn't being used.
05-06-2021, 06:41 AM
Frisco
Can confirm: the correct, Lithium capable units are installed. Ours came off line the 1st week of April, as a point of reference for others awaiting delivery and wondering what they’ll receive.
10-20-2021, 04:10 PM
AUSTIN
Where the hell is the access to the interior wiring harness for a 2021 27’ Flying Cloud. No where to be found. A week now searching everywhere for it to connect interior router to antenna on top. Please help. Dealer nor factory are any help. Drcalvo@me.com or 5125635915 if easier that way. Thanks
Dave
