05-23-2023, 06:46 PM
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale
SmartPlug Extension Cord for an I19 Question
We have a new I19 and my 30’ 30A SmartPlug cord is not quite long enough to reach from my outlet.
Recommendations on what to do?
05-23-2023, 07:10 PM
2015 Interstate Grand Tour
Salem
, New Hampshire
You can either get a 50ft 30A SmartPlug or you can get a 4’ 30A to 15A SmartPlug adapter. Both are pricey but I would get the adapter to have just in case you need to use an extension cord somewhere where there is no 30A connection.
If you’re going to keep it tied at home to a 15 or 20A outlet it will be more than enough to keep you charged up. Just adjust your incoming power to reflect what the outdoor outlet is rated for.
https://www.etrailer.com/Marine-Powe...ug/SM64FR.html
https://www.westmarine.com/smartplug...SABEgK0-_D_BwE
05-23-2023, 07:19 PM
2023 Interstate 19
Scottsdale
I have never seen a 50’ SmartPlug cord?
I need to run the AC mainly here in AZ. So a 15’ 30 extension cord will not work?
I have a 30A outlet outside to plug into.
05-23-2023, 07:34 PM
2024 Interstate 19
Fulton
, Maryland
How much more cord do you need. They make a Smart Plug 25 foot extension for 30A cords - but a bit pricey.
https://www.amazon.com/SmartPlug-CM3.../dp/B08X4YTQTN
Cheaper option is a 30A RV extensions cord like this one on Amazon:
https://www.amazon.com/dp/B0881DFDV3/?th=1
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
05-23-2023, 08:04 PM
2023 Interstate 19
Scottsdale
Originally Posted by Boxster1971
I need about 15 feet max. Why not go with the cheaper option?
05-23-2023, 08:15 PM
Salem
, New Hampshire
You can run your AC from a 20A outlet and the breaker in your AI for the AC is 20A. However, you won’t be able to run any other appliances and you’d want a thicker gauge extension cord. You can also install an EasyStart Soft Start on your AC if the newer AI’s don’t come with one for a lower start up current. You don’t need it but will make it easier on the AC and down the road if you upgrade your battery bank and want to run your AC off them.
Boxster’s extension cord recommendation is a good one too.
05-23-2023, 08:41 PM
2023 Interstate 19
Scottsdale
Thanks for the quick replies. Will try the 15’ extension cord for now.
05-24-2023, 05:58 AM
1994 30' Excella
Mississauga
, Ontario
I have always been able to run my airconditioner on a 15 amp circuit. Even without the easy start that I have installed a few years ago. Use a heavy extension cord to prevent voltage drop. If for some reason the 15 amp circuit can’t handle it, the breaker will trip.
Al and Jean
TAC ON-3
05-24-2023, 08:27 AM
2023 Interstate 19
Scottsdale
Great to know!
05-24-2023, 08:51 AM
2008 22' Safari
Spicewood (W of Austin)
What possible advantage is a “smartplug” over a standard extension…?? Seems to me to be a limitation that forces one to buy only other “smartplug” accys.
05-24-2023, 09:12 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
For use while in the driveway or in storage, I got a very normal extension cord from Lowes(?) and put a Smartplug on the end of it. Easier to deal with than the heavy stock cord. I don't run the A/C while in storage or in the driveway.
05-24-2023, 09:23 AM
2020 23' Flying Cloud
San Antonio
You can get a 50' 30 amp RV extension cord from Amazon.
05-24-2023, 09:28 AM
1988 32' Excella
Robbinsville
, New Jersey
Well, the OP did ask for a Smartplug extension cord.
The only other reasons I can think of is some people like to through away money or claim to have the best of something.
05-24-2023, 10:17 AM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Yeah, I see no need for a Smartplug-specific extension cord. Get a standard high-quality 30-amp cord with a compatible standard 30-amp plug on one end and a standard 30-amp socket on the other. Bob's your uncle!
05-24-2023, 11:12 AM
2023 Interstate 19
Scottsdale
Totally agree! Other than the SmartPlug that connects to the I19 don’t see why you can’t just use a 30A extension cord.
05-24-2023, 11:16 AM
Salem
, New Hampshire
Hi
Yup, did the same with a smaller one for easy storage.
05-24-2023, 11:38 AM
Green Cove Springs
If one just wants to keep the coach batteries charged, that's a fantastic idea.
05-25-2023, 05:01 AM
2014 27' FB International
Clearwater
Smart Plug Extension Cord
BE AWARE
If your intention is to run the air conditioner on the extension cord.
Voltage drop due to wire length can result in high amp loads and possible damage.
If your intention is to just power batteries and other low amp loads length is not so important.
SO.
What to do.
Buy the CAMCO 25 ft 120 Volt 30 Amp extension cord.
Buy a 50A-30A adaptor (dogleg) Great for damaged 30A receptacles.
Buy a plug-in digital volt meter and pay attention to voltage when running the A/C.
105 Volts is the minimum safe voltage.
This is when you try the 50-30A adaptor to see if it gives higher voltage.
05-25-2023, 07:21 AM
2023 Interstate 19
Scottsdale
Originally Posted by ChuckFeldt
BE AWARE
SO.
What to do.
Aren’t the connectors different for 50A/ 3oA?
05-26-2023, 04:20 AM
Clearwater
SmartPlug extension cord
Yes. The Receptacles are different. The 50A-30A adapter has a male 50A plug and female 30A receptacle. Allows you to access the 50A side of the available electric. And a savior when the 30A is damaged. Which is often your first indicator of possible low voltage.
