08-15-2018, 11:58 AM
#21
2017 Interstate Grand Tour Ext
Leland
, Michigan
Whoa...must be my astigmatism causing double vision!
2018 AI “Puckmobile”
“Oh what fools these mortals be...”WBCCI#31111
08-15-2018, 05:24 PM
#22
2011 Interstate Coach
Overland Park
, Kansas
I'd be worried about the added stress put on the existing rear door hinges, especially when the add-on is loaded and swung out. Then there's the rear view camera that would need to be added and wired in.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
08-21-2018, 08:40 AM
#23
2009 22' Interstate
Lake City
, Michigan
Originally Posted by Pahaska
The one item of this scale that I would like to see for the Sprinter is a fiberglass replacement for the sliding door with a swinging door and a window. The swinging door would be much like the door of the Atlas with a pull-out screen. That would make the AI perfect.
I hear ya! That would be a great add on. That said, I wish one could at least convert the side door to a power door. So one wouldn’t have to slam that big heavy door. MB and Freightliner say it can’t be done even though the key phob has a button.
08-21-2018, 11:29 AM
#24
2024 Interstate 19
Fulton
, Maryland
Best Sprinter Rear Storage Option ??
A power slide door is not offered in USA, but is available in Europe. There are a few companies that make add-on power door systems.
Edit: added page from U.K. Sprinter ordering guide that shows the power door. In fact you can see that in UK you can get dual powered sliders, left and right. Same in most of Europe, especially Germany. Here in USA and Canada we only get certain options as determined by Daimler.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
08-21-2018, 12:53 PM
#25
2018 Interstate Lounge Ext
LV
, Nevada
N
Attachment 320464
MIKE - there is an upfitter BESPOKE COACH in (where else, Beverly Hills) that provides the EU sliding door option but when I inquired, was told most of it is part of ground up conversions, although they can do aftermarket at a cost of $8,000. BUT there is the issue of the bathroom that is in the way of making the retrofit, so major expense at teardown on top of that.
Video below
https://bespokecoach.com/gallery/motorizeddoor/
I would love to see how to get the Sprinter 519 Euro Bus conversion by MASCUS in Finland. .This would be my dream Class B setup, where the slider is unused and a pseudo-Class A door is used instead. That is already how we use our AI, hardly ever use the slider due to weight that wife & daughter have tough time using. Can't muster the courage to spend $10,000 on a BESPOKE POWER slider.
08-21-2018, 06:39 PM
#26
League City
Best Sprinter rear storage option is this... NOT. We were parked near this atrocity at Fortress Louisbourg on Sunday and I felt like rolfing when I saw it.
Btw this is called Canada, eh, but it really should be called ClassBLand. Every possible variant and version is found here.
08-21-2018, 08:31 PM
#27
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
Interesting... bicycle carrier
08-21-2018, 11:36 PM
#28
LV
, Nevada
This
08-23-2018, 10:32 AM
#29
Tulsa
, Oklahoma
Originally Posted by VAtom
I'm sorry...that's just wromg
Beauty is in the eyes of the beholder. I'm not a beholder. That is just B-Ugly.
Sorry can't sugar coat it more than that. If you have an extended Sprinter and need this much more room, you need a larger vehicle or need to thin-out the gear on board. Another serious consideration is your GVWR of the loaded vehicle even before the attachment of this storage unit. With the storage unit attached and full, the vehicle loaded with a load of fuel and fresh water, to be safe, weigh the vehicle.
Road Jager
Living On Tulsa Time
