11-17-2022, 10:31 AM
#21
redding
I would lay it on the upper side of you door awning and tie it off at both ends on the locking units??
11-17-2022, 11:04 AM
#22
1999 30' Excella 1000
Chatham
, Virginia
Originally Posted by John Ware
Cut it in half and weld it back together when you get it home.
Sleeve it and pin it. That way you can take it on the road with you anytime..
Could store it inside the camper then.
11-17-2022, 12:22 PM
#23
2012 23' FB International
Woodstock
, Ontario
Originally Posted by SSquared
I'm only semi-serious here, but why not remove the screen from the rear window and put it inside? You would probably need to have a few feet sticking out the back, so you would need to secure the window. I would not want the weight resting on the window frame, so some support would be in order.
Honestly, this would be my solution. It might even fit with the window closed.
We've used our trailer for moving bulky goods from time to time. Payload is certainly not an issue
11-17-2022, 01:20 PM
#24
2019 27' Tommy Bahama
London
, Ontario
It's easier than that, just take the screws out of the back window screen and put it inside.
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
11-17-2022, 02:24 PM
#25
2012 30' International
Livingston
Cut it in half
Cut it in half, stand each in rear corner of pickup bed and fly T 2024 political flags on each. Now, you'll have two flag poles when you get home. /s
11-18-2022, 06:39 AM
#26
2002 25' Safari
Dewey
Most full size trucks are around 20 feet long or more. Use roof racks and have a couple of feet hang over the front and rear. My Tundra has a cap with racks for kayaks which would make it simple for me.
Richard
11-18-2022, 11:50 AM
#27
1960 26' Overlander
Tipton
, Iowa
Maybe not the best idea, but depending on your floor plan can you open the rear window and stick it in all the way to the front of the trailer...making something to support it in the middle. The rear window however would probably need to be open while you are driving...so once again, probably not a good idea.
11-19-2022, 06:39 AM
#28
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Just so I will know. How much does the 28' flag pole weigh? The weight would have a lot of bearing on how I would try to handle it. And if it is 500 plus lbs just writing the check for transport would be in consideration. Maybe find somebody with an empty boat trailer?
11-19-2022, 09:18 AM
#29
2017 25' International
Joliet
I would contact my local electrical contractor and see if they have or know someone with a utility pole trailer you could rent.
11-23-2022, 09:15 AM
#30
2011 25' FB Flying Cloud
Hutchinson
, Kansas
Just get one of these
11-23-2022, 09:33 AM
#31
diesel maniac
Airstream - Other
Tucson
, AZ
Hire the local Boy Scouts to march it home on their shoulders?
Brian
11-23-2022, 10:53 AM
#32
Southern
Originally Posted by Genebuilder
You probably have a high clearance 3/4ton TV to tow your 28AS.
Strap the flagpole tight under the truck carriage, flag each end so it can be seen, and travel home the back roads.
I’ve seem sucker rod and oilfield tubing transported this way when needed. Tito’s Vodka may have been the propellant…
I've done the same. A steel supplier suggested it when I bought some 20' steel.
It made a racket but worked well.
11-23-2022, 11:29 AM
#33
LOS ANGELES
Strap a 16 ft 2x4 to the top of your tow vehicle and strap the pole to that.
11-23-2022, 03:06 PM
#34
Tampa
Okay, since we're tossing out ideas, I'd forget the trailer.
Wrap the middle of the pole with carpet and put it on the truck roof.
Strap it with a couple ratchet straps through the windows if needed. Keep it centered.
Make a cheap crutch for the rear by crossing a couple pieces of 2 x 4.
Tie the front to the front bumper; you see canoes doing this all the time.
There's almost no wind load on a flagpole compared to a canoe or kayak.
Yes it will stick out a few feet in the back, so attach a red flag. The height will be above car roofs anyway.
I read it's legal to stick out 4' behind you and 3' in front.
11-23-2022, 03:41 PM
#35
Tampa
Here's a crutch from a sailboat. It doesn't have to be pretty just function.
