08-19-2020, 10:39 AM
#21
2018 25' International
Slidell
, Louisiana
I should have mentioned that Airstream designers understand the trade offs and try to put the fresh tank between the axles to minimizes cornering instability so if your tank is between the axles, my statement is not accurate, it may well be a slight advantage to carry some water. good catch you guys.
08-19-2020, 10:46 AM
#22
Baltimore
, Maryland
Originally Posted by ROBERT CROSS
TW at the axles...interesting concept.
We always travel with full FW. The tank is between the axles on 'Cloudsplitter' with little effect on towing stability.
YMMV with a front of or behind tank mounting.
I agree adding 400lbs just barely above the axles is a net positive for stability. My TW increases by 20lbs. I’d much prefer to and do run full of water especially if it’s going to be windy. I’ve filled my water tank just for the trip home.
Warning Message
Caution! Most advice given here is nothing more than a subjective opinion. Please reference the vehicles owner manual for instruction on towing and hitch use which is based on physics, facts, and research.
08-19-2020, 04:28 PM
#23
2000 25' Safari
Davidson County
, NC Highlands County, FL
I almost always carry a full tank of water. That way sloshing (weight transfer) is not an issue.
If anyone cares to look back over the last 15 years of posts, there are many old timers like me that recommend and practice this method of keeping the center of gravity low, to improve trailer stability.
Inland Andy, I miss his comments since he left the forum, was one who commented about it often. He even did a write up that was posted on Inland RV's website. Since the new owners, all of his years of shared wisdom is now gone from that website.
Alan
08-23-2020, 05:56 PM
#24
2018 27' Globetrotter
Mooresville
, North Carolina
I was just curious if your tongue weight was 720 vs the 880 you mention. Should it be the difference in what the TV weighs with W/D and what it weighs without the trailer attached (8,080 - 7,360)? Once you add the WD, isn’t the 720 the amount of weight added to the tongue? If you are towing on the ball then I would think that 880 would be the tongue weight. I’m not saying I’m right- I’m just asking the question as I may be wrong in my thinking.
I have the same Globetrotter you and Jeff have. My tongue weight is in the 1,000 lb range as well based on the scales. Like you said, the scales don’t lie so there must be something in the shank length adding addt’l tongue weight for Jeff and me.
Your #’s otherwise look good to me.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
08-23-2020, 06:14 PM
#25
Slidell
, Louisiana
The tongue weight, a load which is torque based, is the downward force generated by the forward bias of the trailer center of gravity and that force is mostly constant, unchanged by the balancing forces of WD. So tongue weight is the non WD addition to the TV. You are however correct that when WD is added the net load on the ball/receiver drops due to a net lift from the bars. In this case to 720 but the trailer is still exerting the same 880 tongue load on the ball.
Hope that makes sense.
08-23-2020, 06:20 PM
#26
2017 16' Sport
N/A
, N/A
makes for nonsense
08-24-2020, 06:03 AM
#27
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
It makes more sense when mentioned that TW is measured UN-HITCHED.
Once hitched that weight is distributed, even without WD.
08-24-2020, 06:18 AM
#28
Mooresville
, North Carolina
Yes, it does. Thanks. As applied to the OP's situation his tongue weight is 880 as tongue weight is determined w/o weight distribution. This is the weight that has to be in the 10-15% parameters. His hitch may have certain limits with, and without WD. I know my 3/4 ton GMC has a strong enough tongue weight without WD so I'm not concerned in my situation and it is within the 10-15% parameters.
However, my previous Suburban had 600 lb tongue weight w/o WD and 1,000 lbs with WD. So, the OP's hitch may have a higher rating with WD since part of that weight is distributed forward and back but that has no effect on determining tongue weight as the tongue weight is 880, determined w/o weight distribution.
Is this correct for the OP?
"Roadrunner"
08-24-2020, 06:47 AM
#29
Slidell
, Louisiana
Yes you have it exactly correct.
08-24-2020, 06:53 AM
#30
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Oh so TW is now considered to be receiver weight hitched WO WD engaged?....Anyone want to buy a TW Scale?🥴
08-24-2020, 07:00 AM
#31
Slidell
, Louisiana
Unless my statics instructor was wrong, they better match up......
In all seriousness, the final Cat scale weights will give you the most accurate indication of true effective tongue weight because the scales are calibrated, they are exactly level and the geometry is exactly aligned so the weight is distributed in equilibrium to the three axles and the effective hitch point will also settle out, so the possibility for measurement error is minimized.
08-24-2020, 12:54 PM
#32
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Brian,
Does this add up...Is it all about the squat?
Our 1200lb (Sherline scale)TW when hitched adds 1920lb to the TV rear axle on the CAT.
I don't believe using the CAT to estimate TW is all that accurate.
Plus on the CAT's the lighter the load the less accurate the results, Plus/minus 50-100lbs would not be out of line.
08-24-2020, 01:19 PM
#33
2021 27' International
Carrollton
Originally Posted by Bill M.
I would strongly prefer 13% tongue weight to 10% tongue weight.
This. All day long - I'd prefer 13%-15%. 10% is down in the nether regions as far as I'm concerned.
08-24-2020, 01:38 PM
#34
2017 16' Sport
N/A
, N/A
Sanity Check on Weight/Distribution
Brian,
[emoji631]
I believe your absolutely right, tongue weight is not isolated when hooked up to TV. When TV is the individual axle weight is what’s important and that reflects the effect of weigh distribution. Weigh your Trailer with weight on the jack and that’s weight before weight distribution. BTW, hitch weights limits by class hitch and manufacturer limits are separate issue. And of course weight limits of the trailer and TV.
08-24-2020, 01:42 PM
#35
2019 25' Flying Cloud
Houston
1,200 lbs tongue weight increases rear axle load 1,920 lbs?
08-24-2020, 02:53 PM
#36
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
When weighing with the Sherline scale make sure you bounce your body weight on the tongue a few times before you read the scale. I found that by just lowering the tongue onto the scale gives an inaccurate reading. Not as much as you are seeing but easily a couple hundred pounds.
08-24-2020, 03:01 PM
#37
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
"Our 1200lb (Sherline scale)TW when hitched adds 1920lb to the TV rear axle on the CAT.
I don't believe using the CAT to estimate TW is all that accurate."
Your weight sure does not sound accurate. I got 800 lbs added to the truck for my 25' when hitched (with the wd engaged). Nobody else has reported the kind of discrepancy you have. Makes me wonder just what you did? wrong?
08-24-2020, 03:35 PM
#38
2017 16' Sport
N/A
, N/A
Isn’t that why one makes a pass with just the trailer the wheel trailer on one scale and the trailer jack stand on the second scale. Curious why that wouldn’t be accurate? How about the section that trailer axles are on is that weight accurate?
08-24-2020, 03:55 PM
#39
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yep... it does, it squats the rear of the TV, removing weight from the front axle, and that weight moves to the rear TV axle.
It can't disappear, it has to go somewhere.🤔
\SNIP QUOTE
"Isn’t that why one makes a pass with just the trailer the wheel trailer on one scale and the trailer jack stand on the second scale. Curious why that wouldn’t be accurate? How about the section that trailer axles are on is that weight accurate?"
I don't use the CAT for TW...the scales aren't really calibrated for light loads.
FWIW my CAT TW was 780lb, Sherline 1200.
I make 4 passes....
1st, just the TV loaded for the trip, now you have the target FAW
2nd TV & AS no WD
3rd TV & AS max WD
4th TV & AS with WD set to the proper returned weight to the FA.
08-24-2020, 04:24 PM
#40
Houston
I see what you are saying. That is without WD engaged.
