08-24-2020, 06:12 AM
2016 26' Flying Cloud
Arlington
, Virginia
3 inch to 2.5 inch reducing sleeve
We are looking to upgrade our tow vehicle to a 2021 F250. We can get a 2.5 inch or 3 inch receiver. We have a Reese Dual Cam that has a 2 inch shank and wanted to upgrade the shank for the F250. Reese makes a 2.5 inch shank, but not 3 inch. I called Reese about a 3 inch to 2 inch reducing sleeve. They said, "We don't recommend it." Are there safety issues or other issues with a reducing sleeve? Any recommendations on which receiver to get?
08-24-2020, 06:29 AM
2012 25' FB International
Trent Woods
, North Carolina
Not a direct answer to your question. My 2500 came with a 2.5 to 2 reducing sleeve which I used with my hitch, at first. But there was a less than tight fit with some rattle and movement that I envisioned causing some long term issues. So, I just bought a 2.5 shank(stinger) for my hitch.
Larry
08-24-2020, 06:30 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I have had no 'safety' concerns with our welded Reese sleeve in our Reese class V receiver.
Added benefit...the pin hole wall thickness is doubled.
08-24-2020, 06:55 AM
2018 25' International
Slidell
, Louisiana
They don't recommend it due to the extra slop possible as Larry alluded in the two adaptors. If you weld the two together and while you're at it, put a bead on the top and sides then grind them down for a nice fit into the receiver as Bob has done, you will be golden.
08-24-2020, 08:06 AM
2019 30' Classic
Canfield
, Ohio
I use one of these on my 2.5" receiver. Works great and no welding. I don't believe it is made in a 3" version.
https://www.amazon.com/Hitch-Clamp-A...g-goods&sr=1-3
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
08-24-2020, 09:20 AM
1976 31' Excella 500
Chappell Hill
You won't ever need a 3" receiver on a 3/4 ton truck. Maybe a few 1 tons might use them for commercial type loads. Not for any RV.
08-24-2020, 09:42 AM
1999 34' Excella
Hillsboro
As Bob did. I have not yet. I grease the sleeve which dampens noise and won’t bind.
Some folks will get elongated hitch pinholes when the receiver wall thickness or strength is marginal.
At any rate, go bigger, weld in the sleeve, carry on.
Peace and Blessings..
Channing
WBCCI# 30676
08-24-2020, 09:49 AM
2018 16' Sport
St. Louis
, Missouri
Any pin product out there to prevent elongated pin holes? Not there yet but I can see the beginning of one, and I am only pulling a sport 16. Thanks.
08-24-2020, 10:22 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Never say never....You will need it if it's the only well designed receiver available that will transfer the needed weight for your rig... our reason.
OEM...... 👎_________________________Reese V👍
08-24-2020, 11:18 AM
2020 25' Globetrotter
Santa Rosa
Has Ford changed the ordering process for the receiver on the F250? When I got my 2017 there was no option; if you bought an F250 gas you got the 2.5" and if you bought the diesel like mine you got the 3".
Anyway, my diesel does have the 3" and when I ordered an Equalizer hitch I specified the 2.5" stinger which is the largest that they offer. I use it with the 2.5" reducer that Ford supplied and it is a sufficiently snug fit that I've not noticed unusual wear or noise. I have had an issue with a not-quite-long- enough angled locking hitch pin but that's another story and that pin has recently been replaced anyway.
I'd rather not use two reducers for the reasons mentioned by other posters (or any at all if possible) and if it were me I would opt for the 2.5" Reese stinger.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
08-24-2020, 11:24 AM
Santa Rosa
Are you using an angled hitch pin? I found that the "crook" of the angled pin was riding right against my receiver and was beginning to cause some wear. A straight pin should solve the problem if that's your situation. They have a good selection on etrailer.com.
Mike
08-24-2020, 12:23 PM
2016 28' International
Trois-Rivieres
, Quebec
Weld + Jam Bolt
Originally Posted by ROBERT CROSS
I have had no 'safety' concerns with our welded Reese sleeve in our Reese class V receiver. Added benefit...the pin hole wall thickness is doubled.
Did the same as Bob, welded the sleeve but the shank still moved a bit within the sleeve, so I had a "Jam Bolt" drilled and welded on top (see photo). The hitch is now rock solid with no movement at all when tightened.
Had the bolt head sized at 15/16" which is the same size as the head of the hot water plastic "bolt" plug, so I can use the same wrench in my tool box when I winterize or de-winterize (which can be more than once per year).
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
08-24-2020, 12:50 PM
2019 25' Flying Cloud
North-Central
I opted to Keep It Simple and got my 2020 F-250 w/ a 2.5" receiver and then upgraded ed my hitch bar (ProPride stinger) to the 2.5" version. Rock solid; no extra moving pieces.
08-24-2020, 09:30 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
3 inch
Equalizer did not have one for our new F-250. Airstream of Ft Meyers parts found us a solid 3 inch shank. Overnighted it as we were there for the setup and install. It is a very solid well built item. Sorry cannot find a name one it. Maybe the Forums will have more information. I did not want a reducer.
08-25-2020, 07:40 AM
Chappell Hill
Bob, I never saw a receiver that small other than on small trucks and cars. What TV did that come off of? Factory hitches that come with 2-1/2" or 3" receivers are plenty strong and similar or bigger than your Reese hitch.
